Refitted TIP again tonight. Couldn't use that tape stuff as it turns out the back is not that sticky and wouldn't hold on to the adaptor so I just refitted it as it was before. I put my hand down to check what it was like before I removed it all and managed to pull the hose away from the adaptor easily. So much for being a tight fit and staying put once the jubilee is tightened as Bill says.
So got the TIP back on and jubilee tightened, seemed OK but by the time I had the DV, N75 etc. in and the filter and heatshield in place the TIP had come away from the stop on the adapter about 5mm and the bottom bend is quite badly kinked.
So tomorrow evening's job - remove the B5 TIP completely and put the THS one back on for now. Going to Edinburgh on Saturday and can't risk the TIP coming off on the motorway. The B5 TIP is getting sold and I'll go for the SFS one on AmD's special offer. I know there's a 3 or 4 week lead time but I'd rather have the THS one on for now and know it's not going anywhere than risk the B5 one, I have no confidence in it now.
In other news, I tried the 008 with the yellow spring and two shims tonight. Still seemed to dump fine but the flutter on boost was still there. Also got
fault code 17608 so I don't know if that's cos the combination of yellow spring and two shims is too tight or what.
In any case, I can ditch the shims and not have to worry about fluttering noise once I get the THS TIP back on and hopefully I'll be lucky like t0m and the SFS TIP won't make any strange noises. I'm sure the B5 TIP works well for lots of people but because of my PITA coolant pipes and the Jabba heatshield it doesn't work for me.
