Richy Cupra
Fully paid member
Jul 6, 2011
1,368
Essex
New coil packs
New spark plugs
New thermostat
New coolant temp sensor
Delock Kit
relocated Fuse 36 (with spare fuses and spare fob battery)
New Brake pedal switch
Removed Splitter
New battery
long long long long
ALSO, THE DAMN BATTERY WAS THE WRONG SIZE!
need to check if eurocarparts made the mistake. hmmmm
not spending anymore on the car now until i sell it in the summer!
That sounds like them. It should be an 027 battery mate :)
bruceR
2,558
647
Monifieth, Dundee
Swapperd my original front wipers & arms for a set of Golf MkIV aero wipers & arms :D
Must say after trimming the passenger side to fit they sit much nicer and better than the retro fit aeros I had.
SubZero
63
Midlands
New Windscreen after she was attacked by a tree when asleep. New Brembo Brake pads for the front, leaky passenger door sealed, handbrake cable greased and a Winter service :) Then a wash on the weekend and that excess windscreen sealent needs to be stripped...
Feb 22, 2006
517
Penzance Cornwall
Polished manifold fitted along with its wrinkled black/polished TB and wrinkle black cam cover, polished up the nuts bolts etc and wrapped the coilpack harness up.
tyrer
OEM
Jun 6, 2010
1,991
Winter mode - standards back on
rob - 73
371
Hamilton / Glasgow
Re fitted front pads, as they were squealing when braking in reverse.
Tried to track down the source of water leaking in to the driver footwell via the bonnet release lever. Removed all the rotten foam seal at the bottom of the wiring loom at the bulkhead and replaced with door seal cord (doubled up for good measure).
Looked for the usual pin hole in the bulkhead seam, couldn't see anything.
So fingers crossed that's it fixed.
G4reth
FR PD170
Dec 4, 2011
393
Middlesbrough
Just had the car through a major service. Had a few things that came up that will need replacing. New brake discs all round and pads. New undertray, and two front tyres.
