Had a focus RS pinned to my sexy rear yesterday so I thought ok then let's play. Unfortunately it's 1-0 to the Ford. Just as I went to belt it the engine management light came on and the car started running very rough. Poodled it home and scanned it with Vagcom:
Address 01: Engine Labels: Redir Fail!
Controller: 1ML 906 032 A
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 66565
VCID: 3FF156082E73
VSSZZZ1MZ5R070305 SEZ7Z0E2876670
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
Readiness: 0000 0000
After reading about it seems its the coilpacks which have gone (rather usual on these cars), however would be great to get confirmation from anyone? At first I thought it's probably the spark plugs as I have OEM plugs on a stage 2 tuned LCR. I have a set of NGK IRIDIUM spark plugs waiting to go on so guess I'll change both at the same time if it is the coilpacks which require changing.
Need to get these sorted before the AmD RR day next Sunday as there's no way I'm missing that
