What turbo are u going to run gt30 or gt35 perhaps
Thinking of either a gtx3071r or a 3076, i think a gt35 would be a bit too laggy.
Gonna go twin scroll to try and get it spooling as quick as possible.
I was thinking of the new GTX range - here's some bomf offof the 034 website -
Introducing the new Garret GTX line of turbos! After setting the standard in turbocharging in the early 2000's, Garrett has stepped up its line of GT turbos back to state-of-the-art status. Have your peak flow and spool it too! GTX wheels are the latest aerodynamic engineering from Garrett Honeywell, essentially what it gets you is the same power as the next biggest turbo but wtih the same surge and spool characteristics. In other words, the GTX3071 spools the same as the GT3071R but flows what the GT3076R does. More power, no compromise.
The above does sounds good to me...
I know the precision turbos seem all the rage at the moment especially with the guys over the pond.
Integrated engineering have been using a 5857 whilst testing there camshafts and have good numbers from them, but that perticular turbo looks to be a bit too large for my needs, i think a CEA 5557 is probably more suited to what i am looking for.
Anyone have any experience with the precision turbo's and are the ceramic centre bearings really worth the extra $550 ???
how. will you manage. Haldex?
Timed it up with 16 rollers between the marks on the cams, the cutouts on the cams are very slightly out to the arrows on the bearing caps but i think its just cos the cam chain tensioner isn't full of oil - its certainly not one tooth out on the sprockets...
Nice build sure is getting there, i had the same problem i removed the cams like twice now an is still in the same location they are slightly off i couldnt understand why it was like that, on the pictures from VW of assemblying cams the arrows are spot on it made me scratch my head for a few days.
Awesome built mate! Looking forward to seeing it run, youll have to get yourself down to the local club rolling road days when its done.
Also join vagcars.co.uk if you would like and get a spare minute, its a north east vag community forum, always good meets etc
Do you think you'll need an IVA to get it back on the road?
