Well i started building the engine up this weekend, Saturday was wasted by picking up the s3 shell but managed to get the cylinder head started.
I've managed to get the exhaust valves installed with the dual super tech valve springs and titanium retainers, i fitted new OEM 3 groove collets.
Couldn't do the inlets cos i only ordered 20 collets (thought they would come in matched sets but are supplied in halfs)
Pics -
Here's a pic of the supertech valve springs & retainers -
So after doing the exhaust valves i overhauled the exhaust hydraulic lifters, just tapped them on the back of a vice until the cylinder assembly came out then cleaned them out and rebuilt them with a bit of fresh oil, they move really nice a freely now.
I also painted the block with gloss black engine paint from Halfrauds, looks really nice now well happy, its a shame you can't really see any of it once the engines in.
Spent about 2 hours this morning cleaning all the swarf out after boring / honing and cleaning all the paint off the mating faces.
Shiney Inner Block -
I also installed the ARP Main Bearing studs and loctited them in -
Installed the Calico main bearings and piston oil squiters -
I used the squirters that came with the APX block as they were slightly different to the AGU ones i was planning on using, the screws are also different, i cleaned them all and blew them through and checked the check valve.
Spot the differences -
The APX ones on the left and 1 AGU one on the right.
Was planning on getting the crank in but the missus invited her mother round for sunday dinner so i was dragged out the garage kicking and screaming....
But not before i managed to drill and pin my TDI crank for the Integrated Engineering Crank Pulley.
Quick tip for anybody using the IE pinned pulley - i didn't fancy just holding the pulley and drilling (not accurate enough for me) so i marked on the side of the pulley with a marker pen where the pilot hole was -
i then nipped up an old crank pulley bolt, i then marked the bolt where it was inline with the mark on the pulley and cut a lump off the head of the bolt to give access to drill the pilot with the bolt tightend up -
Can't wait to get back from work next weekend and finish off the bottom end.
So long for now and thanks for reading.
