Well i've been busy today continuing assembling the bottom end of the engine.
Got the ABA trigger wheel on the crank (bolts right upto the TDI crank, just have to remove the pin), i used some loctite the screws to stop any issues with the screws coming out.
Got the crank in and all tightened up on the ARP Main Bolts - torqued the studs to 60lbs/ft
Used plenty of the Redline Assembly Lube on all the shells to hopefully
help with the intial start-up to stop any picking up on the bearings.
I then cleaned up all the rods prior to fitting, here's a piccy showing the marks where they have been ground when Quasar Engineering balanced them end for end. -
I even got all the piston rings gapped, top rings were gapped to 16thou or 0.40mm in new money, 2nd rings were set to 18thou and the lower oil rings were set about 18-20thou.
I bought a set of fine needle files to set the ring end gaps but the top rings are as hard as a whoares heart so i mounted my dremmel in the vice with a cutting disc in and lightly ground the end of the ring on the flat part of the wheel.
So feeling rather pleased with myself i decided to put a piston in before i called it a night -
Turned the crank and it stopped before reaching BDC - the piston is hitting the oil squirter
I am really sick of running into problems on this build now, gonna have to remove the pistons and have the oil jet relief milled to give about 2mm of clearance....
..another delay but the worst part is i have had all the pistons balanced already so they are gonna need redoing again after the machining work
Oh well on the up side i got my plasma cutter today so might go and take my frustration out on the s3 shell and chop the sh*t outta it.
