Brembo Repaint Complete
Well here are the finished calipers, pics of the prep work can be found in post #698 here:
http://www.seatcupra.net/forums/showpost.php?p=3454514&postcount=698. You can see that they stand out a lot more than the OE coloured ones but they're not OTT. I also had to commit myself to another full detail on the car today after it has attracted some kind of fallout that stuck to the paint which wouldn't wash off with shampoo. So, out with the clay bar, glaze etc and here we have it. I know you can't tell from the pic but this is probably my best job so far, the paint is like crystal
I used the following tools and materials:
- Hammerite Smooth Red Spray Paint
- Brembo Decals (
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220711321934&ssPageName=STRK:MEWNX:IT)
- 1200 Grade Wet & Dry Sand Paper
- Washing up liquid (degreaser)
- Brake cleaner (Degreaser)
The rest were just the tools for jacking the car up and removing a wheel.
Quick
Guide:
- Untighten wheel nuts.
- Jack up car.
- Remove wheel nuts and wheel.
- Wash the caliper with washing up liquid and a sponge, then dry with a towel.
- Spray the whole caliper in brake cleaner, you'll see the stubborn brake dust start to vanish.
- Mask off the areas around that which you are spraying, all of the suspension parts also. I recommend masking off the whole side of the car that you are doing and as far as half of the bonnet also, this is to prevent overspray which you WILL get if there is a breeze.
- Mask off the bleed nipple and also the two brake pad pins.
- Sand back the caliper with the wet & dry until the caliper feels rough and the Brembo decal starts to come off.
- Spray 4 or 5 coats of Hammerite onto the caliper using 15min or 20min intervals between coats.
- Replace the wheel 15mins after the last coat and leave to dry over night.
- Come back 24hrs later and check the the paint has dried solid, sand back lightly any imperfections (if any) and add another coat. Then again leave to dry for a period until the paint has hardened.
- Line up the
sticker on the caliper and smooth it onto it, leaving one edge of the
sticker backing loose so that you can peel it off easily.
- Remove the
sticker backing, check it's straight and then it's done
- Quickly mask off the area again and spray 1 or 2 coats of lacquer if you so choose.
