Well been back to the JKM today to check for any fault codes etc from fitting TIP and cone filter, as was not right friday had 4 faults logged 3 of them were nothing to worry about, one being temp sensor - replaced with green one, second was battery voltage to low - had a new battery fitted so not sure on that one! third fault was the strange turbo pressure to throttle response to slow check dv from friday, had the guys look at it today they cleared everything with VAGCOM and ran some logs, deffo no boost leaks, and everything looks sound in the bay all tight, so cleared all codes and it hasn't come back on, they took it out for a test run all seems great so now error free
, they ran some logs today came back with some great figures! so hoping for a increase now in bhp and torque now!
Also ran me a nice new cold air feed from airbox to where the old intercoolers used to sit, removed the standard plastic air intake jobby!
Goes like a rocket once again
be interesting see how much power now more importantly torque they did mention though im on the limit for the clutch now, and running a new maf which is not genunie one its working fine but vw/audi ones are better so may look into that at some point
Will run some logs with vagcom when i get it don't have a laptop at the mo so friends coming round lol
JKM mentioned these errors may keep coming up, could be due to the AMD remap so i will keep an eye on them this may
help some on here as nothing is wrong with setup seems strange?
Will get some photos sorted in the coming week
