Sent JKM an email asking about the settings for the revo map just to ask if they needed to be increased or adjusted? got a fantastic email back explaining the settings and how they have set it up on the car, the end result is the car is setup perfectly and will not be needing the sps controller after all
JKM have been fantastic and car is running so sweet now very happy!
Hi James
Thanks for the Email.
Your car as per every REVO car that has adjustable software settings (as not all of the do) has been set up by JKM following actual road testing and data logging of various engine parameters, whilst allowing for some overhead which is very important.
We set the REVO settings for you, so that you do not need to purchase an SPS – the setting up is part of what you pay for within the REVO price.
Your cars REVO settings are Boost 7 and Timing 5.
The settings for the REVO code are decided upon after analysing a combination of data channels, including:
Boost pressure (Comparing the Requested against the Actual value) and looking at the N75 duty cycle, i.e how hard the turbo is being worked to make the requested and actual levels meet up. Alongside this, the Ignition timing under full load is assessed, along with Air Fuel ratio and Air temperature – specifically for their influence on ignition retard correction.
We will set the Revo ignition timing setting to ensure that the ECU’s knock correction is not excessive. You can plug in an SPS and increase the Revo timing number but all that the ECU will do is increase the ignition ‘correction value’ which is not good, as you will often feel that the car is not as smooth sitting on large correction values - and this is certainly not the way to tune
I would be cautious suggesting that you increase the Revo boost setting further, as in our experience the LCR K04 turbo is not the most reliable when being pushed hard/aggressive for prolonged time periods – if you set the boost to say 9 for the most aggressive tune, you would need to accept that the life of the turbo may well reduce rapidly as we have seen happen on other LCR’s.
You can purchase an SPS device, however you will need to become competent with data logging, and correctly loading the car up on the road - in order to ensure that the data logs you will be making and the modifications to the REVO settings are correct and accurate.
