Bmc are so restrictive ask badger bill some one who nos what they are taking about , if you can't feel the difference it makes taking it off there is some thing up with your car, I sold mine ages ago
in the know or not, iv read the airflow that my vagcom logged and its fine. albeit iv got extra air coming in from the top of the pipe and iv rerouted the cai to the front grill, but thats just a monkeyspanner job
The BMC will be being fitted, I don't see any harm in giving it a go. I have a brother who is a Master tech at Aberdeen Audi so he will know whats best for my car when he sees the logs, he also has vagcom and a snap on laptop so all the latest software ect.
Iv also maybe managed to get hold of a Forge TIP and Toyo FMIC so fingers crossed :D
Logged this car yesterday now I finally got a laptop that does not need a mains supply to work :cartman:
This car is making just under 200g/s and pulls approx 1.3 Bar of boost.
The car is super smooth, progressive and definitely faster than a standard LCR - using 1.25 as a multiple on the 198.11g/s (which I tend to find pretty accurate), I make it at just under 250bhp :)
Having lost touch with the meaning of figures on the MK1 due to me having a MK2, I am not sure that the timing figures at high revs in this log are either good or bad. Maybe someone more familiar with deciphering MK1 logs can advise?
Ta,
Al
Code:
Tuesday	4	January	2011	16:44:06:65413	VCDS Version: Release 10.6.3 (x64)	Data version: 20101206
1ML 906 032 		1.8l R4/5VT         0001
	Group A:	'002				Group B:	'020				Group C:	'115
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME					TIME
Marker	STAMP	 /min	 %	 ms	 g/s	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	 %	 mbar	 mbar
	587.14	2200	42.1	3.4	14.14	586.54	0	0	0	0	586.83	2040	53.4	970	990
	588.04	1680	17.3	1.7	4.89	587.43	0	0	0	0	587.74	1880	17.3	970	1000
	588.94	1440	42.1	3.4	12.47	588.34	0	0	0	0	588.64	1440	33.8	970	970
	589.85	1640	45.1	3.74	14.81	589.24	0	0	0	0	589.54	1600	44.4	970	980
	590.75	1840	47.4	4.08	17.25	590.15	0	0	0	0	590.45	1760	45.9	970	990
	591.66	2040	48.1	4.08	19.36	591.05	0	0	0	0	591.36	2000	48.1	970	1010
	592.56	1760	17.3	1.7	4.89	591.96	0	0	0	0	592.27	1960	20.3	970	1030
	593.47	1520	47.4	5.1	16.28	592.86	0	0	0	0	593.16	1480	33.8	970	980
	594.37	1640	60.9	5.1	19.5	593.77	0	0	0	0	594.08	1600	62.4	970	1010
	595.28	1800	60.9	5.1	21.42	594.67	0	0	0	0	594.98	1720	60.9	970	1060
	596.18	1920	60.9	5.1	22.83	595.58	0	0	0	0	595.89	1880	60.9	970	1090
	597.09	2040	57.1	4.76	22.22	596.49	0	0	0	0	596.78	2000	60.2	970	1110
	598	2120	32.3	2.72	11.25	597.39	0	0	0	0	597.69	2120	38.3	970	1060
	598.9	2160	30.8	2.72	12.78	598.3	0	0	0	0	598.6	2160	31.6	970	1000
	599.81	2200	30.8	2.72	13.11	599.19	0	0	0	0	599.5	2160	30.8	970	990
	600.71	2200	30.1	2.72	12.78	600.11	0	0	0	0	600.4	2200	30.8	970	990
	601.61	2240	18.8	1.7	7.64	601	0	0	0	0	601.32	2200	21.8	970	990
	602.52	2200	17.3	1.7	7.06	601.92	0	0	0	0	602.21	2200	17.3	970	980
	603.42	2160	18	1.7	6.58	602.82	0	0	0	0	603.13	2200	20.3	970	970
	604.32	1680	15.8	1.7	5.28	603.73	0	0	0	0	604.03	1680	15.8	970	970
	605.24	1640	27.1	2.38	9.64	604.63	0	0	0	0	604.94	1640	23.3	970	970
	606.13	1720	77.4	6.8	28.61	605.54	0	0	0	0	605.84	1680	75.2	1910	970
	607.05	1880	92.5	8.84	36.69	606.44	0	0	0	0	606.74	1800	88	2070	1140
	607.94	2040	110.5	10.54	46.03	607.34	0	0	0	0	607.65	1960	102.3	2150	1310
	608.85	2240	133.8	12.92	64.53	608.26	0	0	0	0	608.55	2160	124.8	2220	1530
	609.76	2520	167.7	15.98	89.83	609.16	0	0	0	3	609.46	2400	154.9	2310	1890
	610.67	2840	191.7	21.08	103.94	610.07	0	0	0	3	610.37	2720	191.7	2310	2510
	611.57	3160	190.2	19.72	114.89	610.97	0	0	0	2.3	611.27	3040	191	2270	2280
	612.48	3480	190.2	19.72	131	611.88	0	0	0	2.3	612.18	3400	190.2	2260	2240
	613.39	3840	187.2	19.38	135.39	612.78	0	0	0	1.5	613.08	3720	189.5	2270	2270
	614.29	4200	188	19.72	148.44	613.69	0	0	0	0.8	613.99	4080	185	2270	2260
	615.2	4520	187.2	19.72	158.44	614.59	3	0	0	0.8	614.89	4400	185.7	2270	2230
	616.1	4840	191.7	20.4	176.44	615.5	3	0	0	3.8	615.8	4720	185.7	2330	2280
	617.01	5120	188	19.38	184.19	616.4	5.3	3	3	3.8	616.7	5040	191.7	2310	2270
	617.91	5400	191.7	20.06	189.78	617.31	5.3	3	3	3	617.61	5320	189.5	2300	2210
	618.82	5640	178.9	18.7	190.92	618.21	4.5	2.3	5.3	3	618.51	5560	178.9	2260	2180
	619.72	5840	171.4	18.02	196.53	619.12	4.5	5.3	5.3	2.3	619.42	5800	178.9	2210	2100
	620.64	6040	169.2	17.68	194	620.02	4.5	5.3	4.5	2.3	620.32	6040	166.9	2150	2160
	621.53	6200	170.7	17.68	198.11	620.93	3.8	4.5	4.5	2.3	621.24	6160	170.7	2090	2060
Some timing numbers came up too those
From what I know anything below about 6.0 at higher revs isn't a big deal. There's a little bit from about 3k on cylinder #4, probably just a tired spark plug or coilpack. Good result Kat :)
EDIT - any idea what map is on the car?
Huge thanks to Al and Willie for logging my car, owe you both a pint! My car was clean until Willie got in the drivers seat :lol:
Its Custom Code Stage 1 Niall. Slightly dissapointed with the results, as the car was advertised for sale as being 275bhp. I knew this was crap as that bhp is definately Stage 2 figures, but I was hoping for more around 255-260bhp. Either way, I would have still bought the car even if it wasn't remapped.
You might be right about the tired spark plug or coilpack, as twice I have thought a coilpack is going.
Away to hit 30,000 miles tomorrow so going to get it serviced, even though it was last serviced at 25,000.
Im still happy anyway :)
Get the air filter in and have the fuel pressure regulator checked by bro Kat :)
Airflow BHP measurements can be slightly misleading tho, especially if the car is remapped. To know what it's really making you'd need to get it on a decent dyno. There's another RR day at Wallace Performance on the 22nd, thread about it in the Scotland section. Why not see if there's still a space? Likely someone will drop out anyway.
Would be interesting to log it again once you've had it serviced, are you getting the spark plugs changed? Mine also felt a bit more up for it after getting the gearbox oil changed.
I will go have a look. I would like to get it on, to get more accurate figures.
I might get the spark plugs changed. My brother will make that decision! Might get new coilpacks too as I luckily get discount on all parts through my brother. He said he was changing gearbox oil :)
Few pics of my baby taken in a light covering of snow. Nothing special but I like it :)
And my little poser!
Yesterday my brother (Audi Technician) kindly did a service on my LCR.
Oil Change
Brake Fluid Change
New Spark Plugs
Gearbox Oil Change
Old spark plugs looking a bit tired!
Exhaust is starting to show it's age a bit :(
I know it's very dirty before anyone says, just haven't had the time/weather to give it a good clean. Summer is on it's way though when it will get a full facelift :)
Bloody hell it must be cold up there judging by those icicles of the splitter!! 30k....im just a little envious!
Very lucky!
We have 2 Cavelier King Charles pups... Fit in the house better than my first choice Golden Lab
The coldest reading in my car was -22 degrees. Its was soooo cold, theres a pic of the front of my car that day on page 7.
It had only 27,997 when I bought it in October, I don't want to put miles on it! :(
Coming along nicely, I can't wait to have some warm weather so I can give the da a crack again (following your tips this time)
Me too Shaun, roll on summer :)
Im sure you will manage, as I say it's not difficult it's just knowing how to use. Check out Polished Bliss website for their advice if you need it. Luckily Im just a short drive from them so their Detailer gave me a one on one lesson. :D
Car is looking well Kat, my 57 plated mk2 is at 27k so 30k on a 7 year old car is brilliant!
Not sure I have seen you at a Aberdeen meet but al informs me that you have the detailing gift? Fancy having an apprentice? :)
