The liner sits snug against the door and then still allows a gap at the bottom of the door and still allows water out. I'll feedback how it goes, vacuumed out the puddle lol
Yeah was fairly easy apart from the paper kept ripping! I loosend the panel and removed all bolts, pulled some of the old seal off to the bottom half of the door and then presed it on ! Were I had removed the old seal, the only time I found the seal to be a pain in the arse was when I was pushing the carrier back up into place ( as the weight o the window had pushed it down ) as the seal wanted to stick to my hand!- the seal isn't sticky until it has been compressed, and the other problem is getting the bolts back in cause the stuff is so god dam thick!
Anyone know if you have to take the front seats out to remove the
wet underlay from beneath the carpet to dry it out properly?
1 buy the stuff of ebay do it once do it properly (imho) search Butyl sealant strip tape
2 It falls off (unless it already as) You leave in to top two bolts
3 Yeah bottom and two side should suffice.
