Water leak into footwell - dodgy seal info and DIY repair guide (Image links dead)
Bunglebonce
Bunglebonce
Jan 21, 2005
247
The Blackcountry
Cheers all.
Bought 2 of the ebay rolls and with delivery it came to £16.50.
Will let you know if I've shot myself in the foot when it arives!
Doubtless it will have 'many other uses around the home' though, if it's no good for the job in hand such as, erm, er, um...
Anyroad two more questions :)
1. Do you scrape all the foam sealer off first, before you apply the sticky rope stuff or do you just stick it on top?
2. Has anyone got the parts number for the plastic clip thingies that hold the door inner on (the ones that with every car I've had they snap the minute you try and take them off).
Cheers again folks ;)
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Cheers all.
Yes, remove the old foam sealer first - water can seep through it otherwise.
Clips: 3B0 868 243 :)
Rauer
You think it's worth doing the regulator clips at the same time ? And anything else in their whilst its off?
53 Leon SX
aka Kris
Oct 22, 2010
528
London
Cheers might order 2 packets then seeing as I'll want to do all four doors. Luckily they're not leaking at the moment. Dad had a brain wave for a short term solution and taped across the seal where the glass meets the door panels and it kept all the water out even though it bucketed down yesterday.
