Well i have been doing a bit of work on the car, my brake servo had decided to give up and die so i got a new one and decided to have ago at fitting it, it was a PITA the engine needs to be moved forward to be able to get it out, so i had to remove the left hand engine mount and the dog bone mount along with every thing on the left hand side, the master cylinder was easy though. I also fitted a new inner CV joint finished my twin air feed, put some new plugs in and uprated the actuator spring as i was getting waist gate creep, the spring has sorted it, the turbo spools up a lot quicker now and holds boost better at the top end. Just need to do my 3" down pipe, to replace the Piper down pipe which is 2.5". The only downer is that i seem to have upset the camshaft sensor which now is throwing a fault code.
