PhilW's Mk3 Ibiza Project Thread - 3071 - Now Breaking!
Nov 2, 2004
9,335
South Wales
What you hopeing for (as is), Phil?
Im not really chasing a figure, more a case of making sure its running ok and safely. But if i was to hazard a guess on a figure it would be in the range of 350-400 and i would be very happy.
Im running 1.5bar and no timing advance (taken a couple of degrees out for safety at the moment as well).
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Laggy Lag Lag and no scream!.... N/A all the way fella :p
Update on my trackday bookings fella, I wanted to do one this week or next but they all at Oulton Park or Cadwell and with at least a 3 & half to 4 hour drive with the trackday starting at 9am stuff getting up that early! Will be a mess half way through the day! lol.
Found that BHP Trackdays are doing an event at Castle Combe the 27th of this month £195 I think! Up for that? They did have afternoon seesions but they booked up.... nothing mention about morning sessions tho???
Nov 2, 2004
9,335
South Wales
Quick log in 4th whilst trying to set up my EBC.
Code:
Group A:	'118
	RPM	Temperature	Load	Absolute Pres.
TIME
STAMP	 /min	°C	%	 mbar
0	2880	14	0	1070
0.8	2920	14	0	1100
1.7	3040	14	95.3	1160
2.51	3160	13	95.3	1230
3.5	3320	12	95.3	1290
4.3	3480	12	95.3	1340
5.1	3640	12	95.3	1410
5.9	3840	12	95.3	1500
6.7	4040	12	95.3	1630
7.5	4280	12	95.3	1780
8.4	4560	12	95.3	2030
9.2	4920	13	73.7	2400
10.11	5240	13	63.1	2470
10.91	5600	14	60	2500
11.71	5880	15	69.4	2510
12.51	6200	15	71.8	2510
Laggy innit?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Code:
Group A:	'118
TIME
0	2880	14	0	1070
0.8	2920	14	0	1100
Laggy innit?
That's awful. Can I see requested v actual?
Nov 2, 2004
9,335
South Wales
I'm gonna try it off the n75 and using a mbc after I do a run on base pressure.
I need to make sure my hoses to the external gate are correct.
Ive got a hose direct from pressure source to the bottom of the gate and a hose from the ebc solenoid to the top connection on the gate.
Boost leak maybe?
Don't think it's an exhaust side leak as my AFR seems right, wouldn't an exhaust leak read lean on the gauge as it pulls in air like a Venturi?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
thats spools more like my gt35, but slightly slower than that too.
its a 0.63 hotside yea?
whats afr doing during spool... if too rich it will slow its spool badly.
my external gate is plumbed single port.. into top port. lag could be gate slightly open perhaps.
what pressure is actuator only?
Nov 2, 2004
9,335
South Wales
I'm not 100% sure, only marking I can see on the inlet side is 0.60a/r.
Afr on spool is around 13 I'm sure.
I run the bottom port direct to pressure source as per tial instructions. Worth trying without?
Around 13psi, so I'm sure it's 0.9bar.
Thanks for the help again bill.
Nov 2, 2004
9,335
South Wales
Ok. I'll try that. I'll get out one night and log more and have a play with things.
I can see some marking on the casting but none that resemble a/r just above the garret logo. Unless it's round the back hidden. I'm pretty sure it's 0.63 tho bill, need to check hoochs thread again I think.
Jan 8, 2007
2,958
Wiltshire
Or join me at Combe on Oct 4th - £179 through Javelin Trackdays :)
Nov 2, 2004
9,335
South Wales
Ok tried some things out briefly with limited road and time.
EBC connected to just the top port as you said Bill. Made no difference to spool or boost control.
Then turned the EBC off, connected to the top port. 30+psi. Still laggy.
EBC off, connected to the bottom port. 30+psi. Still laggy.
When i got home i took a video of the idle AFR, which is bouncing between 14.2 and 15.3 ish. The boost gauge ad EBC doesnt seem to be as low as my old setup which might indicate a leak somewhere which will probably hurt spool.
Im going to do a pressure test on the weekend to see if i got any leaks.
Had a look at my fuel trims and theyre 1.9% and 19.7%. No fault codes whatsoever. Not done a TB alignment and i need to regap my plugs.
