Upon cleaning my car this morning I found a big screw in my passenger side rear tyre! Looks like getting the new set of Goodyears was a timely move, they should be here any day now.
Goodyear Eagle F1 Asymmetrics arrived today, excellent service from Mytyres!
They are being fitted on Thursday, puncture in one of the Falken's is being repaired too, so I can sell all 4.
Yes, Willie is the only guy I use for fitting tyres, balancing and wheel alignment.
Not sure how that is possible considering the THS mounts are the same as ours but Ok ....everyone has there own impressions.The THS mounts are very good, definately stiffer than INA/034 street density and not as stiff or harsh as the track density mounts, they sit inbetween them. There is NO increase in vibration or noise, the best way to describe the THS mounts are tight and sporty. Gearchanges feel smooth, everything feels nice and tight without being harsh at all. Even with the Superpro void fill bushes in there is no vibration. Overall I give the THS mounts 9 out of 10 - great for all but the harshest of driving styles.
Rob, i stripped the same thread on my clutch housing. This felt great but on closer inspection after a day at crail i'd cracked the side of the thread repair. I'd keep an eye on this. Also keep your eyes peeled for a new box as the new OEM clutch housing is £350 and no one will sell a housing second hand as it retains the gear box oil.
You can pick up boxes for about £350 ish. A 4WD 02M box won't be any use to you.
Let me know if you need any other info on this.
I know someone else who's looking for a box and his clutch housing might be spare.
quite close to the shoulder, but i would fix it, if they say otherwise walk away
