Status
Not open for further replies.
If its a chain tensioner/chain problem it would throw a fault. Ive had a fault chain and tensioner and had to replace mine, it was so bad that the chain was actually hitting the calve cover and wearing a nice groove in it. Not good.
The cam position sensor needs to be triggered the same time as the crank sensor and if the chain/tensioner is worn a code of incorrect corelation will be thrown and a EML will come on within a few meteres of running.
Even if it's just getting a bit noisy?
The more I listen around the engine to more it sounds like it's coming from the oil pump area, so before I take the cams etc. out I'm going to take to sump off and have a look. I still have my old oil pump, I can refit it if the new pump is knackered. My old oil pump has only done 38k miles.
Just spotted Camskill are getting in the new Yokohama Advan Neova AD08, 225/40/18 are £149.80.
http://www.camskill.co.uk/products.php?plid=m61b0s134p59615
Today I managed to get the old stripped rivnut out for the lower strut brace. I ended up making some cuts in the head of it with my dremel, pulled off the bits which took all the head off the rivnut and punched it inwards with a quick tap of a hammer and large screwdriver, only took a few minutes!
The new rivnut went in fine but did take some muscle to get it to compress, it's made of steel! But it's in and tight, the strut brace is back on and bolted up tight - job done! :D That's 3 repairs done, 2 helicoiled bolt holes and 1 rivnut replaced.
I also fitted the Powerflex steering rack bush while I had it up on the ramps, what a 'mare of a job but it's done now.
No sign of the rattle/tapping sound anymore, completely gone - weird.
hopefully it was just that then :)
i had a similar noise in the leon i had, it was a "whirring noise" coming from the opposite side to where all the drivebelts where, it turned out it was because I'd drilled and smoothed the airbox so it was the suction sound, but sounded wierd lol, if that makes sense... ive had some koppaburg lol
you do the rack bush with the subframe on rob?
Status
