Condensation in headlights
ado_boro
haha! Tell me bout it! Its was a pain getting them off mine for same reason! No room! Carefull with the clips coz I lost one into the engine bay. Pretty sure ill never see it again lol.
krussel
1,713
Hertforshire
Mine started to condense last year. Left car running on full beam for 20 mins with 2 old sweatshirts covering the lenses, cleared :funk:
Started to come back though :(
Mar 20, 2009
1,707
Largs Scotland
I this will only clear it untill the rain comes back if you pop the bonnet and look at the top of the light you will be able to see where sealer has been put on from factory if you can dry them out again then put some sealer along the top this should help as i found a crack in my and it seems to have worked ok
Stiglet
1,009
Surrey
i had one replaced under warrenty and it is a fault. now the other one has con den in it!! im really not sure about drilling holes as i did this on my fiesta and made no difference what so ever. its only in the winter the con den is a prob. not life threatening..
myneek
100
Winchester, UK
Any idea where you can get a replacement clip? Same happened to mine :lol:
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
Good news, i managed to get rid on the water droplets in the headlights. Full beam with towels covering the lenses and the caps off the back.
However.... my driver side headlight now has a melt bubble in the middle :lol:
What an absolute tit i am, i really should just leave well alone.
Any idea how much for a new headlight from the ****ing stealers? :censored: :censored: :censored: :censored: :censored: :censored: :censored:
Aimez
wind noise
bushes
headlights misting
randm lil things not put on in factory seems no order to it
hight ride height
windscreen freezing on inside!
I'll stop now!
Nothing mechanical on the TDI that I know off so I am happy, had the bushes, freezing screen and wind noise!
Have a look at the thread 'you know you have a mk4 when.....'
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
Im just a bit annoyed atm tbh.
Any car can have faults, but when its a continuing fault through the entire run the car was in production, with seemingly zero attempt to fix or correct the problem.
Its that "**** it, that'll do" attitude that i cant stand.
ado_boro
There is a few going on Ebay at mo, think Ive seen one going for about £60.
ado_boro
I think they are all the same, mine have the gloss black inside bit. Just been looking and found a guy that can do either side for £34.99! Item number is 110495616307 just type it in the search bit on ebay. Hope that helps!
Adrian
kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
Couldnt find a cupra one, are they different? Link if you could?
Are they hard to fit?
No difference still a Twin Headlamp... It's a bumper off job to fit though...
Headlamp - Note the holding screws on the the bottom of the unit, number 18.
Front Bumper - yes the image is of a pre-facelift, I'm sure its the same proceedure for facelift if you have it.
Have a look in the FAQ Section for how to remove the bumper http://www.seatcupra.net/forums/forumdisplay.php?f=199
.G.
ado_boro
Thinking bout it £34.99 seems a little cheap id maybe contact him first before bidding just to be sure. Ive found another for £50 just incase 110464258549
