leon cupra custom fmic install thread, NOW WITH LOGS POST INSTALL
greesha
Leon 1.8T on steroids
Jan 6, 2009
496
Slough
James i can see you are quite happy with this kit :). You even changed your forum avatar and title :D.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
thought id add logs to this thread for people to see and comment on
logs post fmic
Code:
Saturday	6	February	2010	08:59:16
06A 906 032 HN		1.8L R4/5VT      01 0002
	Group A:	'003				Group B:	'115				Group C:	'020
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition
	TIME			Angle Sensor 1	Timing Angle	TIME			(specified Value)	(actual Value)	TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	 /min	 %	 mbar	 mbar	STAMP	°KW	°KW	°KW	°KW
	0.6	2920	82.97	100	15	0.01	2720	70.7	1500	1120	0.3	0	0	0	0
	1.51	3440	115.42	99.6	9	0.91	3080	157.9	2330	1980	1.21	0	0	3	3
	2.41	3960	133.86	100	6	1.81	3600	177.4	2190	2260	2.11	0	3	3	3
	3.32	4480	147.11	100	9	2.72	4160	182	2150	2270	3.02	0	3	3	3
	4.23	5000	162.81	100	14.3	3.62	4680	170.7	2060	2100	3.92	3	3	3	3
	5.13	5480	170.25	100	9.8	4.53	5160	168.4	2090	2040	4.83	3	3	5.3	6
	6.04	5840	172.67	100	13.5	5.43	5560	161.7	2050	1960	5.73	2.3	5.3	5.3	6
	6.95	6160	176.69	100	12	6.34	5960	153.4	2010	1910	6.65	2.3	5.3	4.5	5.3
	7.85	6480	164.39	100	18.8	7.24	6280	147.4	1920	1830	7.55	1.5	4.5	4.5	5.3
pre fmic
Code:
0.01	2760	58.53	65.1	24	0.3	2880	121.8	2110	1630	0.6	3	3	6	6
0.9	3120	104.08	100	4.5	1.21	3320	175.2	2240	2250	1.51	3	3	6	6
1.81	3600	121.64	100	6.8	2.11	3760	173.7	2220	2230	2.41	3	3	5.3	5.3
2.71	4080	139.17	100	9.8	3.02	4240	175.9	2180	2250	3.32	2.3	4.5	4.5	4.5
3.62	4520	147.64	100	8.3	3.92	4680	168.4	2120	2170	4.22	7.5	7.5	6.8	6.8
4.52	4960	164.47	100	7.5	4.83	5120	166.9	2070	2090	5.13	7.5	7.5	6.8	6.8
5.44	5360	164.92	100	9	5.74	5480	159.4	2050	1990	6.04	6.8	6.8	6	6
6.35	5720	170.5	100	10.5	6.65	5880	154.9	2020	1930	6.95	6.8	6.8	6	6
7.24	6040	168.92	100	9	7.54	6120	146.6	1950	1870	7.85	6.8	6	5.3	5.3
8.16	6160	0	5.9	11.3	8.45	5600	10.5	1010	1190	8.75	0	0	0	0
post fmic
Code:
	Group A:	'003				Group B:	'118				Group C:	'031
		Engine Speed	Intake Air Mass	Throttle Drive	Ignition		Engine Speed	Intake Air	Charge Pressure	Charge Pressure		Lambda Sensor	Lambda Sensor	Bin. Bits
	TIME			Angle Sensor 1	Timing Angle	TIME		Temperature	Solenoid Valve	(actual Value)	TIME	Current Value	Specified Value
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	 /min	°C	 %	 mbar	STAMP
	0.25	2440	35.56	21.2	23.3	0.55	2520	15	9.8	1250	0.02	0.984	1
	1.16	2720	68.89	99.2	18.8	1.46	2880	13	74.1	1700	0.86	0.945	1
	2.06	3160	84.92	100	13.5	2.36	3280	12	75.7	1860	1.76	1	1
	2.97	3600	105.94	100	12	3.27	3760	12	84.7	2110	2.67	0.984	1
	3.87	4080	131.72	100	14.3	4.18	4280	12	83.5	2130	3.57	1	1
	4.78	4600	150.33	100	11.3	5.08	4760	14	84.7	2100	4.48	0.953	0.969
	5.68	5080	164.69	100	10.5	5.98	5240	15	85.9	2040	5.38	0.914	0.922
	6.6	5520	168.08	100	11.3	6.89	5640	17	85.9	1910	6.3	0.906	0.906
	7.5	5880	172.14	100	12	7.81	5960	18	86.3	1790	7.2	0.883	0.899
	8.4	6160	168.11	100	14.3	8.71	6240	19	81.6	1800	8.1	0.906	0.906
	9.3	6400	167.81	100	16.5	9.62	6520	20	78.4	1660	9.01	0.891	0.906
	10.22	6680	152.64	100	23.3	10.52	6720	20	78.4	1610	9.92	0.945	0.945
pre fmic
Code:
	0.55	2920	76.03	98.8	21	0.01	2760	30	7.5	1310	0.25	0.977	1
	1.47	3320	122.61	100	6.8	0.85	3040	30	86.3	1970	1.15	1.008	1
	2.36	3800	136.33	100	6.8	1.76	3520	30	79.6	2450	2.06	0.984	0.961
	3.27	4320	145.89	100	9	2.66	4000	32	82.7	2420	2.96	0.922	0.945
	4.17	4760	154.83	100	9.8	3.57	4480	33	84.3	2310	3.87	0.883	0.906
	5.09	5200	165.56	100	7.5	4.47	4920	36	83.9	2230	4.78	0.883	0.891
	5.99	5560	167.33	100	8.3	5.38	5320	39	84.3	2100	5.68	0.867	0.883
	6.9	5920	174.03	100	12	6.29	5680	41	85.1	1980	6.58	0.867	0.875
	7.79	6160	176.5	100	8.3	7.2	6000	45	84.3	1950	7.49	0.875	0.883
	8.71	6440	122.61	79.2	12.8	8.09	6280	47	80	1910	8.4	0.875	0.891
check out the inlet temps decrease, and timing pull now looks acceptible
comments welcome guys, still think i have a fuelling issue, i advanced timing by 1.5 then 0.75... cfs rose slightly, then i retarded timind to -.75 no better than at 0.000 so i left the timing at that.
maf reading looks strong boost seems ok, meeting requested on average
greesha
Jan 6, 2009
496
Slough
Im pretty much crying now over the install of fmic :D. I cant get MAP sensor off old intercooler. Screws are rusty and its just stuck. Looks like i will have to buy a new one - i almost broke it in half when i was struggling to get it off. :(
James what have you done with your horn? Did you unscrew it? Looks like it has to be done.
ANy idea how much new MAP sensor costs ?
james walker
May 24, 2007
5,121
retford notts
didnt touch the horn mate..why dont you strip the head off the screw leaving a bit and unscrew with pliers
new sensors are around 40quid i think.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Any idea how much new MAP sensor costs ?
I had this problem, if you grind the heads of the screws the sensor will come off you just need to find two new screws. ;)
james walker
May 24, 2007
5,121
retford notts
just dont force it and end up stripping the green o ring
oh yeah, the o ring on the mapsensor wont fit in the new map pipe properly, i had to fit one i had here for it to go in, same size just slightly thinner.
greesha
Jan 6, 2009
496
Slough
I drilled the screw out :p Map sensor plastic is broken but i hope it works I've started it up and there was no errors but time will tell.
James, my MAP sensor fitted perfectly.
In general...
Blood, sweat and tears.
If I only knew how much hard work it is i wouldn't probably do it :).
Still plenty to do as i have to trim foglight fitting and put bumper back on.
I wanted to change my grill to honeycomb one but i cant be bothered anymore I guess. Looks like it isnt very easy either.
Few photos
Aug 24, 2007
800
Looks good mate, you got the same filter as me now. Be interesting to see what difference the fmic makes on the rollers as our cars are so similar otherwise.
james walker
May 24, 2007
5,121
retford notts
In general...
Few photos
looks decent mate, i modified mine, where it joins the turbo i cut and shut it so it followed a strait pipe from the top to the turbo, cutting out the bend you have there
tip mate, where youve put the fasteners on the bottom left hand side of the fmic, turn them the other way round so they point into the car, it then allows you to tighten them up if you need to without removing the bumper again....
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Do you think theres any benefit of the 2.5" pipe going to 2" where it meets the turbo?
Mines 2.5" all the way to the turbo but I've read some people [I think RobDon?] use small pipe on the hot side?
james walker
May 24, 2007
5,121
retford notts
no mate, no benefit id say, more restriction than benefit... shouldnt hurt too much on that side though, i just wanted a strait pipe route rather than a bend right near the turbo. just the turbo outlet is smaller so 2 inch makes it tighter on there
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
I would prefer to see 0.8x fueling under boost personally.
dial 5%-10% into increase fueling under load and relog see what it thinks.
