leon cupra custom fmic install thread, NOW WITH LOGS POST INSTALL
jamiebennett81
Great stuff Tony. I'm sending you a pm. I need to make sure everything is fine before RR day.
no worries mate. I suggest we do two runs of each:
2 Runs
G/S and Requested Boost VS Actual
2 Runs
Inlet Temps
Fueling
both to be logged in 4th gear, 2000rpm onwards till the redline
I will check for any error codes as well, clear them at the start and check if they come back (if you do have any of course) :)
p9ve
toyosport fmic
becareful when getting one of these kits as it comes with all the tubes that hardly fit the car.!!! as ive just found out[:@]
greesha
Leon 1.8T on steroids
Jan 6, 2009
496
Slough
Mine doesn't fit very well under the bonnet but i know it was mine fault :). Need to change few pipes around as i have fitted them in wrong order ! But all works fine so i will leave it until it will get warmer :)
greesha
Jan 6, 2009
496
Slough
yes the L shaped pipe is sticking too high but as i said I'm totally aware that this was caused by me.
