Are you running the Unos MBC yet Rob, looking at your previous logs your missing out on a lot of mid range torque that you can now use with confidence with your uprated rods. You want to be peaking to the limit of the map sensor.
Got it fitted yes, just not set up yet. Got an oil change to do then will be out back on the road this week. Yes the Apexi was not giving me consistent boost so torque was suffering, should be able to increase the torque with the Unos (Wallace said this when I was up there on the dyno, should be around 300lbft), I have 'clamped' the MAP sensor and am planning on running 1.8 BAR of boost. CR Turbos confirmed the rebuilt turbo can handle this (uprated bearings are good for 2 BAR).
