air121005
1,609
Worcestershire
I am still mapping it... which given the weather conditions this weekend, is proving tricky..
wet sheeting rain, with cheap ass tyres is not a recipe for traction with this setup.
4th gear wheelspin when boost goes over 1bar. :cry:
Its getting there.. violent little thing
Seeing 1bar boost at 3500rpm in 4th, by 4krpm 30psi & mad wheelspin... Am taming it down, but when its up its away... if only it could find traction that is.
:shrug:
the battle continues..
:whistle:
:think:just a thought.....rather than battling the elements, wouldn't an hour on a local dyno be more productive than trying to keep this animal on a wet, leaf strewn roads? :shrug:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
tyres are cheap for a reason
1st bill needs to be payed for this biuld
2nd carnt get any toyo R888
dont think its on part throttle at 30 psi
part throttle its tractable... thats not a problem, but full beans - lol - is another ball of wax :D
wooshy... wayhay
R888's in this weather will be worse.. too cold for them also.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
And more legal. :p As I'm sure anything over 3rd gear and it's over the 60 limit....
4th gear wheelspin in wet currently.. as soon as load builds it spins it away..
road logging and driving is the best final way of doing it imho, as the car drives on a real road not RR... However.. If I had the £30K I needed to buy a DD rolling road I would do so in an instant as its a great tool to use to do the main load checking, safe inside a dry building at daft wheelspeeds, strapped going no where and final trims if required on the real road logging.
all RR donations greatfully received :)
couple of pix from the weekend
shiney black sealed inlet now.
Craig1985
Did deep bill be nice to get a go in this when we come down to pick her up eh matey!!!!
Race on with the polo TDI!!!
Jun 1, 2007
760
how do you get on with it, seeing how its set with the very small display.. I could'nt make out which settings were record from still etc...
dinky little critter tho
had about an hour playing did take abit of working out. only worked out the video setting for now display is very small as is the cam happy with it
you worked yours out yet bill
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
no, mines been sat on the side since trying to use it once at combe
