gearbox oil
stucupra r
156
doncaster
anybody got a guide to where to fill and drain and how much to put in. also is it worthwhile putting some sort of antishock gearbox oil. thanks
Aug 7, 2009
1,395
Manchester U.K
You will need the correct socket which is a spline one, there is one on the side of the box to fill up which is near the starter and the drain is on the very bottom.
Draper do these quite cheep as i bought one when i had to resort to mole grips on a bora once :(
http://cgi.ebay.co.uk/Draper-Expert...tZUK_Hand_Tools_Equipment?hash=item20adac0bbb
Just fully synthetic 75/90's will do mate.
http://www.opieoils.co.uk/c-673-75w-90.aspx
Fuchs TITAN SINTOPOID SAE 75W-90 synthetic gear oil is good stuff, as is the motul, and the silkolene depends how much you want to spend. When i done the seals in my box il be filling it with the titan sintopoid.
stucupra r
156
doncaster
thank you very much mate most helpfull
csd_19
2,280
28
Angus / Edinburgh
Only reason I say to check is my 02M uses a hex instead of the torx one ;)
Could be the later boxed cars use a torx, mine is a 51 plater.
Aug 7, 2009
1,395
Manchester U.K
Ages since i filled one but arroun 2 litres, yeh usual procedure of filling till it runs out, allow it to level for a second then put the plug back in.
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
I think mine took 2.4 as i remember i bought what i was sure was enough but then had to drive to two stealers for some more. Make sure its dead level when you fill dont attempt to jack it up just on the front. On my cupra r it was a security spline as pictured above but my 5 speed mk4 gti was a hex.
