What are you on then?Correct me if im wrong but im sure Rob had one of these many moons ago.
what log is timing pull again Rob? need to get this measured on mine....and Bill said to me no more than 5
also what "scale" did you use for the MAF Rob? mine was 204g/s last time (LC sensor in LCR housing) ??
Friday 21 August 2009 10:06:00
06A 906 032 HN 1.8L R4/5VT G01 0002
Group A: '020
Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition
TIME Angle Delay Angle Delay Angle Delay Angle Delay
Marker STAMP °KW °KW °KW °KW
0.01 0 0 0 0
0.28 0 0 0 0
0.58 0 0 0 0
0.88 0 0 0 0
1.18 0 0 0 0
1.48 0 0 0 0
1.78 3 0 0 0
2.09 3 0 0 0
2.4 3 0 3 3
2.7 0.8 0 0.8 0.8
2.99 0.8 0 0.8 0.8
3.3 0.8 0 0.8 0.8
Friday 21 August 2009 10:22:54
Group A: '002 Group B:
Engine Speed Engine Load Injection Intake Air Mass
TIME Timing TIME
Marker STAMP /min 0% ms g/s STAMP
0.01 3200 47.4 4.76 28.86
0.3 3320 48.9 5.44 34.28
0.6 3480 74.4 7.48 54.92
0.9 3680 92.5 8.84 71.5
1.2 3920 112 10.54 93.86
1.5 4280 145.1 13.26 130.11
1.81 4680 174.4 13.6 161.56
2.1 5240 180.5 14.28 185.47
2.42 5480 185 17.34 196.03
2.72 6000 180.5 23.12 204.83
3.01 6080 174.4 22.44 199.78
3.32 6480 167.7 21.76 204.83
3.62 6760 164.7 21.08 213.19
Could be from here.
HHHmmmmm not too sure Rob. I would say if it's not 100% OEM then the figures are sent into too many possible errors that the above calculations mean nothing. Butt dyno tells allShouldn't it be scaled first, LC sensor in LCR housing?
