Status
Not open for further replies.
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
I can wrap most simple shape's with "real" carbon fiber ;)
Saw your build thread, and I have to say it was funny reading the one about you just got the carbon kit.. you know, the one that you were asking too much. :cartman:
But that carbon kit is different altogether than Rob's sticky Carbon Sheet.. right? I wanna wrap my AGN Engine Coverrr. Forge doesn't make one for my non turbo engine one. :p
RobDon
Pro Detailer
Rob, if you have some of the carbon sheet material off cuts, try aplying the gloss on that first before you do anything to the mirror covers. In that way if your test piece rejects the gloss then atleast your view mirror case will not be screwed.
I took a small offcut and stuck it on an old container and gave it a couple of light coats of gloss clearcoat - and it worked. Seems to have taken ok and is quite shiny, looks like it will need a few coats to build it up into a smooth layer but it looks like it will work, I'll get some pics soon.
Indy
MK1 LC Red Devil :)
Sep 8, 2005
200
Uxbridge
Sounds good so far, lets hope the second coat stays and you can paint the wing mirror covers and hopefully the B pillars.
Just an Idea, Have you thought of covering the steering wheel with this stuff? I bet it would look good.
Spud_G40
PS3 Gamer tag: SRedx
Jun 12, 2006
397
Glasgow
nothing I reckon, just solely for cosmetic purposes unless you are running very high powered applications like GT2871+ etc
How exactly?
Even the GT2X hybrid Rob is running will probably be achieving the same peak boost levels as a GT2871R etc anyway. No matter how much boost your running if its hard piped it going to be better, less chance of leaks/collapsing.
RobDon
Pro Detailer
Exactly, I think Jamie is just guessing wrongly, most people including Bill go for as much hard pipe as possible.
I installed the APR fuel pump today, pretty easy job, took about an hour to do, peace of mind now knowing the pump is good for up to around 360bhp.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
rob have you thought of hireing a mandral bender from hss for example, you could make your own pipes then and its only circa £20 to hire one.
Spud_G40
Jun 12, 2006
397
Glasgow
Rob did have a walbro pump fitted previously? What was the reason to change it if so?
Where abouts does the APR pump fit.
Just out of curiousity
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
Well I don't know if it just me.. anyone seen a Pagani Zonda with those Full Carbon In-dash trim?
Your little mod reminds me of that. I don't think it would hurt too much to the eye going "OTT" if you're going to fully trim the dash with the carbon, no?
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
Hi, just wondering what was done to the front centre grill, has the number plate plinth just been removed if so how or something or is there more too it?
Adam
Status
