Status
Not open for further replies.
jamiebennett81
Yeah I won't go mad with it, just nice subtle changes. I'm still planning on doing the headliner in black alcantara sometime so may do the pillars with the carbon trim - can't beat carbon and suede!!! ;)
who do you order it from and how much again? also how big is the sheeting....good value for money?
when doing curved parts i.e. corners of wings mirrors etc, is it just a case of sticking, bending and stretching the material etc to give a nice fit?
looks pretty durable from the video....
RobDon
Pro Detailer
The sheet is big, 50 inches by 24 inches and it is durable yes. It is just a case of manipulating it round corners etc., but I was careful to try and keep the weave pattern straight when stretching it, but it is easy to work with and is mega-sticky!
Link to it above. It's around £29 including delivery, mine arrived in around 4 days.
RobDon
Pro Detailer
Well my DV failed today because of the water injection it seems. When I took it apart the insides had moisture all over it and the spring had white corrosion on it. Even after cleaning and re-lubing it still wouldn't work properly, so I have ordered a new Forge 007P to replace it (it was a Bailey DV30). I think I'll need to move the DV takeoff to before the WMI nozzle so it doesn't happen again.
RobDon
Pro Detailer
New Forge 007P arrived today, along with new vacuum hose and 25mm hose too. I now have the DV fed from the coldside pipework before the WMI nozzle, so it shouldn't be affected by moisture now.
I'm hoping to do some logging in the next few days and start advancing the timing.
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
just to add you cannot lacquer the cf stuff, tried it today and it just goes black haha so this means its satin finish only,
i found a uk supplier of this a few weeks back, theres is about £60 for 1m x 1.3m inc del
hth
jake
Status
