Hi guys,
I thought i would try and clear this up for people who are thinking of trying to get a flip key. I've included the step by step instructions again (they are identical near enough to the ones gaz put up when he created this thread) I just want to thank all the people who have put posts up on here to
help us noobs.
You will need to get your key if you have one starting 1JO 959 it will operate the boot release, if you choose a key with 1KO 959 it wont (if im wrong with that let me know) i tried both keys on my car and only the 1JO worked the boot.
The MHz doesnt make any difference as 434MHz is backward compatible.
To program the key you need to do the following:
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the
coding
procedure. The remote control will now be programmed.
This is the procedure i followed to program it to my car.
To build the key you can do the following:
If you open the spare key you will need to look for the transponder. As Stu put in his post it is down the bottom in the little alcove.
Be careful when trying to remove it as i found mine to be glued in. To get mine out, i had to cut the side of the spare key up a little to get a scalple in to remove the glue.
This is what it looks like once its removed:
Put the transponder into the little hole on the top half of the flip key and sercure it in otherwise it'll just rattle around. I personally put a dab of blue tack in. There is a slightly lighter end to the transponder, i dont know if its required to be, but i would advise that end to go in first (closest to the blade) only because thats the way it comes out of the spare key.
Close the key up and bingo your sorted, now you just need to get the blade cut.
My local Timpson's did the cutting for me and did it free of charge as they dont guarentee it'll work.
If they do screw it up you can buy top halves of the keys dirt cheap like this one off eBay (its the one i bought)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=290325530512
i hope this makes things clearer without the need of reading the whole thread again. (if any of the previous members want me to delete this let me know, i dont want to tred on peoples toes)
