i have to follow which procedure to configure the key fob ?yup, it is luck if it works or not tho! it might have woked on mine but its not 100% sure it will work on yours!
i only have one key with a chip, my spare key doesnt have anything inside it. its just a blade that open doors and starts engine?
can this stil be done?
Sure there is a immo chip inside the "dumb" spare key too.
If there wasn´t the car would not start, would it?
The two halves come apart when you insert a thin blade between them and pry gently.
The immo chip is attached inside with some glue.
well i did think that but i cracked it open and there seems to be nothing in there..??theres a gap for it but nothing there?
does anybody know if there is anything different between the model numbers ending AH and DA??
