Getting the cupra to 300bhp?
icemancupra
Newbie
Apr 3, 2006
78
What is the most cost effective way of getting the 1.8t cupra to 300 bhp?
is there a direct replacement for the k03s?
can it just bolt on? or is a new manifold required?
ATP gtx2 or a k04 upgrade?
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
You could get a k03 hybrid (which is basicaly a k04 inside a k03) which will give you ~280bhp, but you will need a high flow manifold.
Standard manifold is only good for ~250bhp.
What is your budget?
icemancupra
Newbie
Apr 3, 2006
78
Do not really have a budget but I wouldn't really want to spend say over 4k or so say . . . .
just like to price things up.
how much more would the gtx2 be compared to the k04 hybrid? what other bits would I need?
injectors, new manifold, TIP, new exhaust?
Damoegan
Oct 15, 2007
8,993
Newcastle
For your budget I would go for a GT28.
Either way you go you will need:
Larger injectors
Larjer MAF
LCT/TT or custom TIP
Hight flow mani to suit what ever turbo you go for
Larger down pipe with high flow cat and cat back exhaust
Uprated engine mounts
Maybe uprated intercooler piping.
Try asking Bill (Badger5 section), he can put togeather a kit to suit your budget.
icemancupra
Newbie
Apr 3, 2006
78
Thanks for the reply.
gt28 is abit over kill if your just after 300bhp isnt it? think if seen a mk3 running 350+ power. If your only after 300ish brake would that be the best option?
Just because I have 4k to spend i'd like to save a little for a few track days :whistle:
With the 280bhp k03 hybrid would you need new injectors?
Damoegan
Oct 15, 2007
8,993
Newcastle
Ko3 hybrid requires LCR/TT injectors mate.
What about a IHI VF34, max out at ~320 but with a good 300bhp tune.
icemancupra
Newbie
Apr 3, 2006
78
so if your changing the turbo to any other you would need to change all of the things been listed? and the difference is just the turbo?
icemancupra
Newbie
Apr 3, 2006
78
Trouble is I have read alot about big power cars (from standard) having issues, I want something reliable aswell as quick. There any company's who do a bolt on kit for the ibiza?
Damoegan
Oct 15, 2007
8,993
Newcastle
If I were in your shoes I would go to Badger5.
Only bolt on stuff I know of are the GT2x and mose people say they are poo....
Ric 2001
Need an ID-ten-T form
JBS IHI STAGE 1 For all 150 & 180 Bhp 1.8 20VT (exc. Ibiza (6K)):
Uses the famous IHI roller-bearing turbo. Combined with the JBS ST321SS SC10 stainless-steel tubular manifold, it can easily provide power outputs of:
300-350bhp.
Basic Kit Includes:
•JBS IHI Turbo
•JBS IHI Tubular Collected Manifold
•JBS 3" Custom Downpipe
•JBS Custom Top Boost Hose
•JBS Custom Intake Pipe Coupler
•JBS Custom Braided Coolant Feed Lines
•JBS Custom Braided Oil Return Pipes
•JBS Custom Banjo Bolt
•JBS Mk3 Ibiza Top Boost Hose
•Oil Feed Washer
•10mm Oil Feed Copper Washer
•14mm Coolant Return Washer
•Gasket Kit for the Above
£2227.37 inc vat
JBS also recommend that you buy with this kit:
•Forge Motorsport Turbo Intake Hose - £100
•Forge Motorsport Diverter Valve - £80
•Milltek Sport CAT-back Exhaust System - £200
•Green Cotton Filter/Induction Kit - £60
•Vibrotechnics Uprated Engine Mounts - £600
•Genesis Uprated Injectors - £60x4
•4 Bar Fuel Pressure Regulator - £60
•4 Bar Fuel Pump - £350
•3" Air Mass Meter (150 & 180 bhp versions only) - £100
Plus fitting £500 + software.
icemancupra
Newbie
Apr 3, 2006
78
Thanks for the breakdown Ric 2001!
So thats everything I would need? What would the fitting for the turbo, manifold etc be?
Would a DIY be possible? then take it to get mapped etc
