LC APR Stage 1 - updated logs...
Nov 29, 2007
736
Mansfield, Notts
Ran the car the other week at RS Tuning RR day and it only made 186bhp. Now I know there is the old dyno lottery but I was first on at 10am and last time on the same rollers I made 173bhp with out the APR stage 1 and CAT back system. I was expecting around 205-210bhp maybe more if I was lucky.
Don't really know what I'm looking for - so any help or advice would be much appreciated. I can upload the data in a different format or e-mail it required.
Thanks in advance...
EDIT: Logs remove and replaced with better ones below.
EDIT: Updated logs in post 28 - comments/advice welcome.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Very hard to see whats going on there as everything is too small, J.
Just copy and past straight from the excel file and add (code) before and (/code) after but replace () with [].
Nov 29, 2007
736
Mansfield, Notts
Ok mate I'll sort it lunchtime today. I thought it was hard to read but didn't know you could to the (code) thing.
Damoegan
Oct 15, 2007
8,993
Newcastle
None of them can realy be called a power run, J.
You need to do them in either 3rd or 4th and go from about 2.5k rpm to redline with no gear changes.
Might be worth asking Dave to have a look too.
Nov 29, 2007
736
Mansfield, Notts
Ok mate... the wife was driving cause it was the first time I've ever logged anything. Now I know how it works I can go and to a full run in 3rd.
Last night I got her to go from 2k, then slow down and boot it in the next gear from 2k.
I've got so many questions:
1). Block 003 - what should a strong MAF slow on the air flow?
2). Block 115 - what should be the requested/spec boost be on a mapped car?
3). Block 118 - what should the air temp do, go up, level out, decrease?
4). Block 118 - should the duty cycle be 0 or nearly 100 all the time, what is a good number(s)?
5). Block 032 - should the O2 Adapt be a negative number?
6). What do blocks 002, 114, 020, 031 tell me, and again what are good numbers?
I'll PM Dave like you suggest - I'm sure between the pair of you I will find out whats what.
Thanks mate... J
Damoegan
Oct 15, 2007
8,993
Newcastle
Thanks mate... J
1) MAF on a mapped k03s car sould be circa 170g/s @ ~6k rpm
2) Depends on the actual map. On my stage 1 I was getting about 1.1-1.2 bar requasted. Spec (actuale) boost shoule be nearer enough what the requasted is, sometimed its higher.
3) Air temp should come down a little from ambiant temp then start to rise as you get higher up the rev range.
4) Duty cycle should be between 70-90% I think. Duty cycle is how much the ecu is telling the wast gate to open to hold the boost requested (I think).
5) I think its your lambda sensors.
6) I think its your A/F (air fuel mixture)
I',m sure Dave will be along soon to put me straight :)
Nov 29, 2007
736
Mansfield, Notts
New logs
Done some new logs lads. Couldn't manage 4th gear so I did the best I could in third.
Code:
Friday        12June             2009  19:35:11
06A 906 032 MJ  1.8L R4/5VT         0003
        Group A:'003                                    Group B:'020
                Idle speed  Air mass Throt AnglIgnit Angle      Idle StabilizatIdle StabilizatIdle StabilizatIdle Stabilization
        TIME    700-820 rpm 2.0-4.5 g0.2-4.0%  0-12 BTDCTIME
Marker  STAMP    /min        g/s     %          °BTDC   STAMP    CF             CF             CF             CF
            0.01        1400    12.33       9.4       18     0.4              0              0              0            3.8
            0.81        1480    12.22       9.4     24.8    1.21              0              0              0            1.5
            1.71        1600       18      13.3     23.3    2.22              0              0              0              0
            2.62        1760    20.72      16.1     23.3    3.02              0              0              0              0
            3.42        1920    12.83       9.4     27.8    3.82            1.5              0              0              6
            4.33        2080    36.53      99.2     10.5    4.73              0              3              3            0.8
            5.13        2320    53.69       100      9.8    5.53              0            2.3              3              0
            5.93        2640    68.47       100      6.8    6.33              0            2.3            2.3              0
            6.73        3000    91.64       100        6    7.15              0            1.5            2.3              0
            7.64        3480   128.19       100      3.8    8.04              0            1.5            2.3              0
            8.56        3960   127.11       100      7.5    9.07              0            1.5            1.5              0
            9.56        4480   137.39       100     11.3    9.96              0            0.8            4.5              0
           10.36        4880   148.06       100     10.5   10.78              0            3.8            4.5              3
           11.26        5280   154.14       100     13.5   11.68              3            3.8            3.8              3
           12.07        5560   156.64       100     13.5   12.48              3              3            3.8              3
           12.89        5840   158.67       100     15.8   13.37            2.3              3            3.8            2.3
           13.79        6120   162.83       100       18   14.19            2.3            2.3              3            2.3
           14.59        6320   163.92       100     17.3      15            4.5            5.3              3            1.5
            15.5        6520   158.42       100     23.3    15.9            4.5            5.3            2.3            1.5
            16.3        6680   158.94       100     19.5   16.71              0              0              0              0
           17.21        6480    11.53       9.4     17.3   17.59              0              0              0              0
Code:
Friday        12June                2009     19:37:18
        Group A:'115                                            Group B'031
                Engine Speed  Engine LoaSpec. Boost  Actual Boost      Lambda FactorLambda Factor
        TIME    700-6800 RPM  15-150%   990-1800 mbar<=1800 mbarTIME
Marker  STAMP    /min         %          mbar         mbar      STAMP
             0.4          2120      81.2         1910       1100   0.01        0.984            1
            1.21          2360     116.5         2030       1450    0.8        0.922            1
            2.21          2800     150.4         2140       1880   1.71        0.922        0.906
            3.02          3160     172.9         2180       2180   2.62        0.875        0.867
            3.82          3600     182.7         2150       2250   3.42        0.867        0.867
            4.73          4000     168.4         2160       2160   4.22        0.852        0.867
            5.53          4360     164.7         2100       2120   5.13        0.875        0.867
            6.43          4760     160.2         2050       2050   5.95        0.867        0.867
            7.25          5080     154.9         1990       1990   6.85         0.86        0.867
            8.05          5360     152.6         1960       1940   7.65         0.86         0.86
            8.84          5640     148.1         1920       1910   8.44         0.75        0.782
            9.77          5920     142.1         1870       1870   9.26         0.75         0.75
           10.57          6160     139.1         1840       1820  10.17         0.75        0.743
           11.37          6400     134.6         1800       1780  10.96         0.75        0.735
           12.17          6640     125.6         1770       1720  11.77         0.75        0.727
           12.97          6800     123.3         1740       1700  12.57         0.75        0.743
Code:
Friday        12June                2009    19:39:40
        Group A:'118                                           Group B'032
                Engine Speed  Air Temp IBoost Dut CyActual Boost      Idle O2 AdapRun O2 Adapt
        TIME    700-6800 RPM  <=110 C   0-100%      <=1800 mbarTIME          -10.1       -10.1
Marker  STAMP    /min         °C        %            mbar      STAMP  %           %
            0.01          1960        36           0       1010   0.49         2.1        -2.3
            0.89          1880        36           0       1010   1.31         2.1        -2.3
             1.8          1960        36        95.3       1090   2.21         2.1        -2.3
            2.61          2200        34        95.3       1370      3         2.1        -2.3
            3.42          2520        33        95.3       1690   3.82         2.1        -2.3
            4.22          2880        32        83.5       2020   4.62         2.1        -2.3
            5.04          3280        32        87.8       2320   5.42         2.1        -2.3
            5.84          3720        33        85.1       2140   6.24         2.1        -2.3
            6.73          4160        35        85.5       2160   7.13         2.1        -2.3
            7.55          4600        37        85.1       2070   7.95         2.1        -2.3
            8.35          5000        39        84.3       2000   8.75         2.1        -2.3
            9.16          5320        42        84.7       1950   9.55         2.1        -2.3
           10.06          5680        46        88.2       1890  10.46         2.1        -2.3
           10.86          5960        50        93.7       1850  11.27         2.1        -2.3
           11.77          6240        52        87.1       1810  12.17         2.1        -2.3
           12.57          6520        55        79.6       1750  12.99         2.1        -2.3
           13.39          6720        57        79.6       1700  13.79         2.1        -2.3
           14.19          6920        59        79.6       1700  14.59         2.1        -2.3
Damoegan
Oct 15, 2007
8,993
Newcastle
Hmmm :think:
Boost looks fine, actuale Vs requested are good but your pulling some cf's for some reasone. Intake temps are hight which could be the case..
Thoughts, Dave?
Damoegan
Oct 15, 2007
8,993
Newcastle
Block 020, cf's = correction factors accross the cylinders, where the ecu is pulling timing back therefore reducing power.
Damoegan
Oct 15, 2007
8,993
Newcastle
Yea, MAF reading looks a little low. I'd expect in the region of 170g/s. Might be worth trying a cheapo open cone filter to see if it helps with airflow. I noticed a difference when going from a Green Panel filter to pen cone.
I was pulling similar g/s to you when on stage 1 map but I had a problem with the map.
Nov 29, 2007
736
Mansfield, Notts
Clean the TB today and used VAG-COM to reset it. Now the CF's are worse. I thought that would help?
Code:
Saturday      13June            2009  21:03:39
        TIME    700-820 rpm2.0-4.5 g0.2-4.0%  0-12 BTDCTIME
Marker  STAMP    /min       g/s     %          °ATDC   STAMP    CF             CF             CF             CF
             0.4       2280    24.89      15.3     25.5    0.01              0              0              0              0
            1.31       2520    56.67      99.6     10.5     0.8              3              0              0              0
            2.11       2840    79.67       100      6.8    1.71            3.8            5.3            3.8              6
            2.91       3240   105.83       100      3.8    2.51            3.8            5.3            3.8              6
            3.72       3600   120.86      98.8      2.3    3.31              3            4.5              3            5.3
            4.52       4000   129.86       100      1.5    4.12              3            4.5              3            5.3
            5.34       4400   137.69       100        6    4.94              3            3.8              3            4.5
            6.14       4800   143.28       100      9.8    5.74            2.3            3.8            2.3            4.5
            6.94       5160   148.47       100     10.5    6.54            2.3              3            5.3            4.5
            7.85       5520   154.03       100       12    7.36            1.5              3            5.3            3.8
            8.65       5800   154.14       100     14.3    8.25            1.5              3            4.5            3.8
            9.47       6080   159.97       100     17.3    9.05            1.5            2.3            4.5              3
           10.36       6320   160.22       100     17.3    9.96            3.8            5.3            4.5              3
           11.16       6480   155.28       100     19.5   10.76            3.8            5.3            3.8            2.3
           11.98       6560    22.22       6.3       18   11.58            3.8            4.5            6.8            5.3
736
Mansfield, Notts
Ok, cleaned the MAF and the Green panel filter at the weekend and it looks like its now pulling a few more g/s and carmed down the CF's a little. I did two runs tonight and both showed a small improvements:
Code:
Tuesday       23June            2009 19:18:23
        Group A:'003                                  Group B:'020                                                         Not Running
                Idle speed Air mass Throt AngIgnit Angle      Idle StabilizIdle StabilizIdle StabilizIdle Stabilization
Run 1          0       2320    26.67     16.1       27    0.35            0          4.5            0            3
            0.76       2600    58.53      100     13.5    1.16            0          4.5            0            3
            1.56       2920    88.81      100      8.3    1.96            0          4.5            0            3
            2.36       3360   127.28      100      0.8    2.76            0          3.8            0          2.3
            3.16       3800   127.94      100      0.8    3.58            0          3.8            0          2.3
            3.98       4200   137.89      100      3.8    4.38            0            3            0          2.3
            4.78       4640   147.94      100      7.5    5.18            3            3            3          1.5
            5.59       5040   154.22      100       12    5.99            6          2.3            3          1.5
            6.39       5360      158      100      9.8    6.79            6          2.3            3          0.8
            7.19       5680   160.56      100     14.3     7.7          5.3          1.5          2.3          0.8
            8.09       6000   167.28      100     19.5    8.51          5.3          4.5          2.3          0.8
            8.91       6240   165.69      100       15    9.32          5.3          4.5          1.5            0
            9.82       6480   164.25      100     19.5   10.22          4.5          4.5          1.5            0
           10.62       6400    17.92      7.1     37.5   11.02            0            0            0            0
Run 2      32.54       2120    13.64        9     30.8   33.05          2.3          1.5            0            0
           33.54       2280    48.81     99.2       15   33.94          2.3          4.5            0            0
           34.34       2560    66.53      100        6   34.76          2.3          4.5            0            0
           35.25       2960    98.25      100      2.3   35.65          2.3          3.8            0            0
           36.05       3360   125.14      100        3   36.45          1.5          3.8            0            0
           36.87       3800   129.17     99.6      4.5   37.38          1.5            3            0            0
           37.86       4240   141.67      100      6.8   38.28          0.8            3            0            0
           38.68       4640   146.42      100     10.5   39.17          0.8          2.3            3            0
           39.59       5040    150.5      100     12.8   39.99          3.8          2.3            3            0
           40.39       5360   156.94      100       15   40.88          3.8          1.5            3            0
           41.28       5680   162.56      100       12    41.8          3.8          1.5          2.3            0
           42.19       6000   163.58      100     17.3   42.61            3          0.8          2.3            0
           43.91       6520   165.17      100     19.5   44.31          2.3          3.8          1.5            0
           44.72       6440    20.06      7.8     17.3   45.12            0            0            0            0
