LC APR Stage 1 - updated logs...
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
g/s looks fine now but its still pulling too much cf's for some reason, J.
Can you do some more of blocks 115 and 031, then 118 and 032?
Nov 29, 2007
736
Mansfield, Notts
Yeah can tomorrow night... was just about to try and log them when the wife's laptop died on the passenger seat.
Got a fuel filter to change this weekend and see if that has any effect. Only changing/doing one thing at a time to try and narrow down the problems one by one. Gonna try and find out info on the FPR and see if thats an avenue to look into.
Not really sure at the moment on what direction to take... any advice would be appreciated.
I'll do the logs tomorrow night and post up ASAP.
Damoegan
Oct 15, 2007
8,993
Newcastle
See what the other logs come out like first.
Have you cheched your spark plugs? Only about £16 for a new set so that could also be worth a try too.
Nov 29, 2007
736
Mansfield, Notts
Yeah I can whip them out and give them a quick check - but they only went in a couple of months back. Although I didn't gap them. Assumed they were right straight out of the box.
Where did you get 4 NGK Platinum plugs for £16?
Nov 29, 2007
736
Mansfield, Notts
...been ages since I updated on this issue. I've come to the conclusion that it is heat soak issues. Over the last week the car has been driving a lot better in the cooler conditions. Going to VAG-COM when I get a chance (...meaga business in general).
Ordered a FMIC cooler of eBay yesterday evening - would like to go Forge (etc) but don't have the funds. So I'll aim to get that fitted by the end of August.
Nov 29, 2007
736
Mansfield, Notts
New logs - think I might of sort it...?
Ok... I never got round to fitting the FMIC in the summer for one reason or another but i think that it was only half the problem - my PCV spider of pipes was totally knacked.
I've removed this and now have a catch tank... the car has never run so well and if I've understood my logs correctly they appear to agree.
Comments/advice welcome:
Code:
Sunday         8November        2009 16:25:57
06A 906 032 MJ  1.8L R4/5VT         0003
        Group A:'003                                  Group B:'020                    Group C: Not Running
                Idle speed Air mass Throt AngIgnit Angle      Idle SIdle SIdle SIdle Stabilization
        TIME    700-820 rpm2.0-4.5 g0.2-4.0% 0-12 BTDCTIME                            TIME
Marker  STAMP    /min       g/s     %         °BTDC   STAMP    CF    CF    CF    CF   STAMP
               0       2160     6.36      3.9     30.8     0.5   3.8     6     0     0
             0.9       2240    45.83     99.2       18    1.31     3   5.3     0     0
            1.81       2600    80.33      100        3    2.21     3   5.3     0     0
            2.72       3080    99.03      100        3    3.12   2.3   3.8     0     0
            3.52       3480   113.31      100      5.3    3.92   0.8   2.3     0     0
            4.32       3920   119.97      100     10.5    4.72     0   1.5     0     0
            5.13       4360   134.17      100     12.8    5.63     0     0     0     0
            6.03       4800   143.17      100     15.8    6.43     0     0     3     0
            6.83       5160   151.53      100     17.3    7.25     0     3     3     3
            7.76       5560   160.11      100       15    8.16     0     6   2.3     3
            8.56       5880   162.28      100       18    8.96     3     6   5.3     3
            9.36       6200   163.08      100     20.3    9.76     3   5.3   5.3   2.3
           10.17       6440   164.67      100     21.8   10.67     3   5.3   5.3   2.3
           11.07       6480    16.44      8.2     22.5   11.47     0     0     0     0
           11.87       6080    14.69      9.8     13.5   12.27     0     0     0     0
           12.77       5600    13.58        9     11.3   13.17     0     0     0     0
           13.58       5200    12.92      8.6      7.5   13.98     0     0     0     0
Code:
Sunday         8November    200916:26:51
        Group A:'115                            Group B:'031                            Group C: Not Running
                Engine SEngine LSpec. BoActual Boost    Lambda FLambda FBin. BitBin. Bits
        TIME    700-680015-150% 990-1800<=1800 mTIME                                    TIME
Marker  STAMP    /min   %        mbar    mbar   STAMP                                   STAMP
               0    2040    13.5     990    1020     0.4   0.750   0.852
             0.8    2120    96.2    1850    1240     1.2   0.969   0.945
             1.6    2400   136.1    2010    1750       2   0.899   0.883
             2.4    2720   169.9    2110    2230    2.82   0.867   0.867
            3.31    3160   166.2    2140    2140    3.71   0.860   0.867
            4.11    3520   172.2    2110    2130    4.51   0.852   0.867
            4.93    3880   162.4    2090    2080    5.33   0.860   0.867
            5.73    4240   160.9    2070    2090    6.14   0.836   0.867
            6.64    4680   157.9    2010    2030    7.04   0.867   0.867
            7.44    5000   152.6    1960    1970    7.84   0.867   0.867
            8.26    5360   151.1    1920    1900    8.65   0.867   0.867
            9.06    5640   148.1    1880    1870    9.55   0.805   0.813
            9.97    5960   143.6    1820    1820   10.37   0.750   0.774
           10.86    6240   135.3    1790    1800   11.26   0.750   0.766
           11.66    6480   132.3    1760    1750   12.08   0.750   0.758
Code:
Sunday         8November    2009     0.7
        Group A:'118                            Group B:'032                            Group C: Not Running
                Engine SAir TempBoost DuActual Boost    Idle O2 Run O2 A
        TIME    700-6800<=110 C 0-100%  <=1800 mTIME       -10.1   -10.1                TIME
Marker  STAMP    /min   °C      %        mbar   STAMP   %       %                       STAMP
             0.4    2520      24    95.3    1270       0    -1.3    -3.1
            1.31    2880      24    77.6    2130    0.81    -1.3    -3.1
            2.11    3240      24    78.8    2190    1.71    -1.3    -3.1
            2.93    3640      24    78.4    2160    2.53    -1.3    -3.1
            3.82    4120      26    80.4    2120    3.42    -1.3    -3.1
            4.64    4480      27    80.0    2050    4.24    -1.3    -3.1
            5.55    4920      30    78.8    1980    5.13    -1.3    -3.1
            6.45    5320      33    78.4    1910    5.95    -1.3    -3.1
            7.26    5640      36    80.0    1870    6.84    -1.3    -3.1
            8.06    5920      39    80.4    1810    7.66    -1.3    -3.1
            8.86    5920      39     0.0    1190    8.46    -1.3    -3.1
            9.66    5680      36     0.0    1050    9.26    -1.3    -3.1
Damoegan
Oct 15, 2007
8,993
Newcastle
Much better now, Jason. Boost is spot on, MAF could be a little higher (5-10g/s), fueling is fine and the cf's have come right down.
I'd still like to get the cf's down a little more though.
Damoegan
Oct 15, 2007
8,993
Newcastle
The TIP will smooth airflow out, deffo worth doing.
As James said, check your plugs out.
What fuel are you using?
A large open cone filter will help gain a few g/s.
Nov 29, 2007
736
Mansfield, Notts
I'll be doing the TIP weekend are next hopefully...
Always Tesco 99 unless I'm caught out and then its Super only - APR map was for 98ron.
Changed the fuel filter and plugs in the summer - but the running issues could of knacked the plugs; stick with the NKG's or go for cooler ones?
Will start looking into open cone - fancy a bit more DV noise anyway...
Nov 29, 2007
736
Mansfield, Notts
Ths tip + cone filter
After hours out in the cold my hard work has been rewarded with... more CF's and no more g/s!!! [:@]
My intake temps where higher on a cooler day so I can only assume it was the open cone drawing in warm air. Couldn't try the air-box again because the THS TIP is a cr@p fit and is pver an inch short by the MAF.
Code:
Sunday        29November    200912:40:11
                Idle speAir massThrot AnIgnit Angle     Idle StaIdle StaIdle StaIdle Stabilization
        TIME    700-820 2.0-4.5 0.2-4.0%0-12 BTDTIME                                    TIME
           21.02    1920   33.28    89.4    17.3   20.52       0       0       0       0
           21.82    2200   48.83     100       9   21.42       3       0       3       3
           22.73    2640   77.78     100       9   22.23       3       0       3       3
           23.53    3120  107.31    98.8     0.8   23.13     2.3       0     2.3       3
           24.35    3560  114.97     100     4.5   23.93     2.3       0     2.3       3
           25.26    4040  123.94     100     6.8   24.84     2.3       0     2.3     2.3
           26.15    4560  135.03     100       9   25.75     2.3       0     1.5     2.3
           26.97    4960  147.44     100      12   26.55     1.5       3     1.5     2.3
           27.77    5320  151.75     100    12.8   27.37     1.5       3     4.5     4.5
           28.66    5720  160.75     100      15   28.27     0.8       6     4.5     4.5
           29.58    6080  162.56     100    20.3   29.08     0.8       6     3.8     3.8
           30.38    6320  164.64     100    17.3   29.98     0.8     5.3     3.8     3.8
           31.19    6560  162.28     100    25.5   30.79       0     5.3       3       3
Code:
Sunday        29November    200912:44:05
           12.48    1960    60.2     970    1110   11.98   0.992   1.000
           13.39    2040    57.9     970    1060   12.88   1.016   1.000
           14.38    2280   107.5    1970    1400   13.88   0.938   1.000
            15.2    2600   136.8    2090    1840    14.8   0.992   0.930
           16.09    3120   175.2    2150    2330   15.69   0.883   0.875
           16.91    3480   168.4    2120    2130   16.49   0.860   0.867
           17.71    3840   162.4    2120    2100   17.31   0.860   0.867
           18.51    4280   162.4    2110    2140   18.11   0.860   0.867
           19.42    4720   159.4    2040    2050   18.92   0.852   0.867
           20.32    5120   151.9    1960    1960   19.84   0.867   0.867
           21.13    5480   150.4    1930    1890   20.73   0.789   0.797
           22.03    5840   146.6    1870    1860   21.63   0.750   0.766
           22.83    6160   139.8    1820    1820   22.44   0.750   0.766
           23.64    6480   132.3    1770    1750   23.24   0.750   0.735
Code:
Sunday        29November    200912:45:50
            10.5    1840      33      58    1140      10    -1.3    -4.7
           11.31    2080      33    76.1    1310   10.92    -1.3    -4.7
           12.21    2400      34    95.3    1670   11.81    -1.3    -4.7
           13.03    2840      35    80.4    2110   12.61    -1.3    -4.7
           13.94    3360      36    81.2    2190   13.52    -1.3    -4.7
           14.72    3680      37    80.4    2170   14.32    -1.3    -4.7
           15.65    4120      39    82.7    2150   15.14    -1.3    -4.7
           16.55    4560      41    82.7    2090   16.15    -1.3    -4.7
           17.36    4920      44    80.4    1990   16.95    -1.3    -4.7
           18.26    5280      46    80.4    1930   17.84    -1.3    -4.7
           19.17    5600      49    82.7    1920   18.66    -1.3    -4.7
           20.07    5920      51    82.4    1900   19.67    -1.3    -4.7
           20.88    6160      54    81.2    1800   20.47    -1.3    -4.7
           21.68    6440      56    78.4    1780   21.28    -1.3    -4.7
Damoegan
Oct 15, 2007
8,993
Newcastle
:think:
Its not too bad, Jason. I wouldn't expect any more g/s after fitting a TIP, just smoother airflow.
Have you tryed using another fuel just to ruel it out?
Nov 29, 2007
736
Mansfield, Notts
I've also fitted the Ripspeed open cone so I was expecting more g/s. I had no choice but to fit the cone filter as the THS TIP was to short. It sounds nice but just a bit gutted after spending time in the cold.
I've re-aligned the TB this afternoon and will but some 99 in tomorrow (running 97 last week).
The only upside I can see at the moment is requested Vs. actual appears to be stronger in the mid range.
Damoegan
Oct 15, 2007
8,993
Newcastle
The first lambda reading is actual and the second is requested (opposite way round to block 115 for some reason).
Nov 29, 2007
736
Mansfield, Notts
Block 031 is very similar to last time.
Block 115 looks slightly stronger.
Block 118 is showing higher temps all the way up.
Block 032 run O2 is also lower - could the be due to the TB before I reset it or because I'm using 97 instead of 99?
I did manage one 3rd gear run that gave a 169 on the g/s.
