LC APR Stage 1 - updated logs...
Nov 29, 2007
736
Mansfield, Notts
Think I will. I nearly always use TESCO 99 but the last couple of times I've filled up I've been totally out and and it's been get to the nearest garage ; Sainsbury's and then a Total.
Think I'll fill up at Shell/BP a couple of times.
Although I suspect I wont see the end of the high CF's until I've fitted the FMIC and got the temps down. It will have to stay as is for the RR @ Awesome in a couple of weeks.
Nov 29, 2007
736
Mansfield, Notts
Logs after fitting FMIC
Ok... fitted an FMIC at the weekend (well a mate did most of the work). What do you think?
You'll see from the block 118 that the temps have come down big time. Pre FMIC was done at outside temp 15 degrees C and today I logged and it was 24 degrees C. So even through it was a lot hotter I was still well under the pre FMIC run.
My problem is that there is a massive whistle sound... my daughter helped with the logging and she said it sounds more like someone squeezing air out of a bottle (think she right as well).
Pre FMIC:
Code:
Friday        18June        201011:22:32
06A 906 032 MJ  1.8L R4/5VT         0003
        Group A:'118                            Group B:'020                            Group C: Not Running
                Engine SAir TempBoost DuActual Boost    Idle StaIdle StaIdle StaIdle Stabilization
        TIME    700-6800<=110 C 0-100%  <=1800 mTIME                                    TIME
Marker  STAMP    /min   °C      %        mbar   STAMP    CF      CF      CF      CF     STAMP
           108.2    2320      39    95.3    1490  108.62     1.5       3     2.3       3
          109.02    2600      39    89.8    1970  109.52     4.5       3     2.3       3
          109.91    3000      40    83.9    2120  110.31     4.5     2.3     1.5     2.3
          110.73    3400      42    82.4    2220  111.13     3.8     2.3     1.5     2.3
          111.53    3760      44    82.4    2160  111.93     3.8     1.5     0.8     1.5
          112.33    4120      45    83.5    2180  112.75     3.8     1.5     0.8     1.5
          113.13    4520      48    82.4    2120  113.55       3     0.8     0.8     1.5
          114.04    4920      50    81.2    2050  114.44       3     3.8       6     0.8
          114.96    5280      53    83.1    1960  115.35     2.3     3.8       6     3.8
          115.77    5560      56    83.5    1900  116.17     2.3       3     5.3     3.8
          116.57    5840      58    80.8    1920  116.97     1.5       3     5.3       3
          117.37    6080      61    81.6    1840  117.77     1.5       3     4.5       3
          118.17    6320      63    78.8    1790  118.59     1.5     2.3     4.5       3
Post FMIC
Code:
Wednesda      23June        201020:22:47
        Group A:'118                            Group B:'032                            Group C: Not Running
                Engine SAir TempBoost DuActual Boost    Idle O2 Run O2 A
        TIME    700-6800<=110 C 0-100%  <=1800 mTIME       -10.1   -10.1                TIME
Marker  STAMP    /min   °C      %        mbar   STAMP   %       %                       STAMP
            0.01    2440      39       0    1030    0.37     2.1   -14.1
            0.87    2560      39    95.3    1130    1.36     2.1   -14.1
            1.78    2960      36    95.3    1730    2.18     2.1   -14.1
            2.58    3360      34    95.3    2160    2.98     2.1   -14.1
            3.38    3800      33    95.3    2140    3.89     2.1   -14.1
             4.4    4320      33    95.3    2080     4.9     2.1   -13.3
             5.3    4760      35    95.3    2010    5.81     2.1   -13.3
            6.29    5240      37    95.3    1840    6.71     2.1   -13.3
            7.11    5600      39    95.3    1790    7.52     2.1   -13.3
               8    5960      41    95.3    1750     8.4     2.1   -13.3
            8.82    6200      43    87.8    1710    9.22     2.1   -13.3
            9.63    6480      45      80    1690   10.13     2.1   -13.3
Code:
Wednesda      23June        201020:25:28
        Group A:'115                            Group B:'031                            Group C: Not Running
                Engine SEngine LSpec. BoActual Boost    Lambda FLambda FBin. BitBin. Bits
        TIME    700-680015-150% 990-1800<=1800 mTIME                                    TIME
Marker  STAMP    /min   %        mbar    mbar   STAMP                                   STAMP
            0.42    2040    48.9    1580    1020    0.01   0.922       1
            1.31    2280     112    1990    1280    0.91   0.953       1
            2.11    2520   138.3    2130    1530    1.71   0.969    0.93
            2.93    2880   165.4    2180    1830    2.53   0.883   0.875
            3.93    3320   191.7    2160    2150    3.42   0.867   0.867
            4.73    3720   187.2    2170    2130    4.33   0.867   0.867
            5.63    4160   177.4    2160    2070    5.23    0.86   0.867
            6.45    4560   172.2    2090    1990    6.05   0.828   0.836
            7.36    4960   166.2    1990    1880    6.86   0.813   0.821
            8.27    5320   156.4    1950    1830    7.85   0.782   0.774
            9.15    5680   148.9    1900    1780    8.75   0.774   0.766
            9.97    5960   144.4    1860    1750    9.57   0.758    0.75
           10.78    6200   140.6    1820    1710   10.38    0.75   0.743
           11.58    6440   133.1    1770    1710   11.18    0.75   0.727
           12.38    6560    27.1    1000    1530   11.98   0.782   0.743
           13.18    6440    11.3    1000    1070   12.78   0.867   0.961
Code:
Wednesda      23June        201020:20:11
        Group A:'003                            Group B:'020                            Group C: Not Running
                Idle speAir massThrot AnIgnit Angle     Idle StaIdle StaIdle StaIdle Stabilization
        TIME    700-820 2.0-4.5 0.2-4.0%0-12 BTDTIME                                    TIME
Marker  STAMP    /min    g/s    %        °BTDC  STAMP    CF      CF      CF      CF     STAMP
               0    1960   20.61    12.5    22.5     0.4       0       0       0       0
             0.9    2160   44.39    99.2    14.3    1.41       0       0       0       0
            1.81    2480   64.97     100       9     2.3       0       3       0       0
             2.7    2840   87.22     100     5.3     3.1       0       3       0       0
            3.52    3200     115     100     2.3    3.92       0     2.3       0       0
            4.32    3600  131.33     100     3.8    4.81       0     2.3       0       0
            5.23    4040  139.56     100       3    5.63       0     2.3       0       0
            6.03    4440  145.47     100     8.3    6.45       0     1.5       0       0
            6.85    4800  150.92     100    10.5    7.33       0     1.5       0       0
            7.74    5200  154.83     100      15    8.14       0     3.8       0       0
            8.54    5520  159.69     100      15    8.96       0     3.8       3       3
            9.34    5800  164.11     100    15.8    9.76       0     3.8       3       3
           10.16    6080  165.69     100      18   10.56       0       3       6     2.3
           11.07    6320  164.25     100    19.5   11.57       3       3       6     2.3
           11.97    6520  109.06    89.8    17.3   12.37       0       0       0       0
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Looks much better now mate :)
Looks like you might have a tiny boost leak somewhere, try nipping up the hose clips a little bit more..
Nov 29, 2007
736
Mansfield, Notts
Was thinking that myself... Looking back my older logs I was bang on requested Vs actual. So there is a good chance I've not got a FMIC coupler out of line or slightly loose.
Will have a look over the weekend and try logging again next week - but in general it car is running sweet going by the logs...
Also going to order up a Jetex filter and see if there are a few more g/s in there.
Damoegan
Oct 15, 2007
8,993
Newcastle
Here's one of mine from last July..
Code:
Group A:	'118
	Engine Speed	Air Temp In	Boost Dut Cyc
TIME	700-6800 RPM	<=110 C	0-100%
STAMP	 /min	°C	%
0.4	3400	26	85.1
1.31	3920	25	85.1
2.11	4200	24	85.1
2.93	4560	25	85.5
3.84	4960	26	87.1
4.73	5320	27	87.5
5.63	5600	28	87.5
6.45	5920	29	87.5
7.25	6120	30	87.5
8.16	6320	31	87.5
9.07	6560	32	87.5
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
The N75 will cycle the wastegate closed to control the boost, then start to open it more as the K03S runs out of puff.
With yours at the moment, its keeping it open to try to get more boost (trying to compensate for the leak).
Nov 29, 2007
736
Mansfield, Notts
Thanks for all the help guys - but another question...
If I use a leak tester can I go through the 25mm pipe that joins above the turbo (i.e. take it off the bottom of the DV)? Or should I test further down stream on the hotside FMIC pipework in both directions?
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
stick a cork in the end of the hose that goes from catch can to tip. oil cap off, and pressure test through charge pipe on turbo outlet.
