Gibon
The right compressor from GT2052V Turbo. There are 2 different wheel designs.
To implant the bigger turbine in GT17 housing, there is cnc-machine work required.
Greets, Alex
2 different wheel designs ? OK. I didn't know.
THX
Greets, Alex
I like the sound of being called legend lol yeah mine is so loud, loudest I've heard yet, and a few neighbours have actually made complaints lol, police came round and said the exhaust needs to be removed cause not having a cat and back box is illegal, after I told them no! Go do one and research about diesels they said my exhaust is legal and I can keep it, me 1 cops 0 lol, I'll get a video clip up soon mate
LOL, thats a good one.
You will never ever get 240-260bhp out of any hybrid done from a GT17 hotside.
The required mass air flow and thereby showing up exhaust gas amounts outflow the GT17 turbine @ about 210bhp.
Even VNT20 turbine is way to small, it is only a few (8) % over GT17VB turbine.
For 240-260bhp you need at least GT22 turbine and to have clean combustion you need at least 59 or 60mm compressor.
If you dont bother smoke, you can get about 235-240hp with 56mm compressor, but this is with lambda 15,5:1 so it will smoke very well*g*
Torque btw comes from injection quantity, not from decision which turbo is used.
And btw nr2:
To big compressor with to small turbine causes boost creep which can only be solved by reducing injection quantity.
You can see this even on "standard" GT1752V hybrids, the duty cycle for N75 will be @ 95% @ about 3700-3800revs, upwards from there there is no more possibility for vnt mechanism to reduce boost, only way to reduce=reduce IQ.
Greets, Alex
i've been reading this thread all week on my mobile, but not had chance to post all week (would take to long on my phone)
i may be going over old ground here as i understand that you've sorted it with the relevant parties and i'm pleased that you've got your car running, on stage 1 remap and i admire your persistance in going hybrid, but as going hybrid could be an option in the future i got a few questions......
it was the wrong turbo hybrid'd & fitted
IMO, thats a bit of a fook up and personally i wouldn't be overly impressed at paying for, IIRC did you say ~£1500, on parts and services when they were wrong!!!
so has what you have spent to date been refunded or has it been put down to experience?.........
now regarding mapping.
call me niave if you must but i thought that when a hybrid was fitted, a custom remap was created for that cars setup utilising every possible mod to get the best out of the car.
but i've read all the posts as saying the map installed was for a different turbo
so is custom hybrid mapping, not that custom and more of a generic map like a stage 1 or is it more of a case of installing a base map then tweaking it from there to utilise mods, a bit like a stage 2 map?
what happened regarding this post below?
did you ever find out what the cause of this?
has this been rectified, has it caused damage to anything else?
have other parts failed because of being put under excessive stress?
regarding turbos, now i didn't realise there was a difference between a hybrid'd PD130 & PD150 turbos i thought that once hybrid'd they were the same unit
what sort of power difference figures are we talking between the 2 differnt turbos?
and you say there are different stages of tune, again whats the difference in bhp and torque?
just for clarity, these are mearly questions and not digs at any relavant parties.........
I'm so surprised I didnt get a boost pipe pop off when it was under 35psi of boost! Goes to show I do my jubilee clips up "man tight!"
I wasn't aware either - I thought the GT1749VA and the GT1749VB were the same turbo housing, but with different internals and that both had the same power capabilites once mapped. I have since learnt (I believe) that the PD150 turbo housing is bigger than the PD130.
Turbo Dynamics claim 200-220bhp on a PD130 stage one hybrid. Then 220-240bhp on a stage two PD130 hybrid.
On the PD150 hybrids they claim 220-240bhp on a stage one hybrid, the stage two PD150 hybrids are claimed to produce 240-260bhp. So there must be a difference. The same work is done to them both, although a larger compressor wheel is fitted into the PD150's which therefore must mean it's bigger! I cant give you the torque differences as they only quote bhp on the Turbo Dynamics spec sheets.
I hope this helps!
I have the turbo spec sheets, if you want me to write up what's done to them all then I will be more than happy to! Hope this has answered a few of your questions. I'll no doubt be in the wrong for answering them but as you say - they're mearly questions and not a dig at "relevant parties."
yeah, thanks for the honest response!
glad you've not ended up out of pocket on this.
agreed, unless you were going to take the turbo off yourself and check it over for part numbers, how were you to know?
looking at those power figures TD quote, i can see why you want a PD150 to hybrid
i would be interested to know what is done to a turbo when it gets hybrid'd, if you got time to post up the details
oh and what brand of jubilee clips do you use and where do you get them from?
I hope your not using the camera in Auto mode, Ash What carera did you get?
Tbh I'd heard that Sony's arent as good as Kodak for example, but this camera is apparently quite new out and it's won best camera award or summat. And for someone that doesn't know too much, that swings it.
I have a rough idea how to do HDR pictures. You do one underexposed, one normal and one overexposed, then layer then all on top of each other i think?
Sony do good DSLR cameras but the only thig with them is that you have to use Sony only accessorys (lenses, flashes etc).
Yep, for HDR you need at least 2 pics with different exposures but I find 3-5 different exposures give you the best results. I use Photomatix to convert into HDR.
the SEAT Sport FMIC looks fooking massive behind the grills
why didn't i buy it
have you noticed any difference from the Forge
why didn't i buy it
