That is the fuel cooler!! with a long cover over it will be modifiy mine with a NACA scoop [simlar to what VW golf/passat have on the front under bib of the engine - when the weather improvesI can see some sort of silverish long thin radiator type thing but that is all...this runs flat underneath the car directly underneath the drivers side-is the DPF above this, which means it cannot be seen?
Some pics from somebody to compare would be good please...
Good job M.Shark
I'm just about to remove PDF from my a3 2.0 170 tdi - I know that you did it , and my question is _ How your " ex seat tdi " behave , and If You had any problems in longer period after changes made _ ?
Good job M.Shark
And I guess if you have an accident and it is noticed to be missing (long shot i know) you would be completely and utterly f****d!Yep, u just bolt it back on for MOT. With regards to road tax, u just pay same amount as a non modified tdi fr. Aftermarket modified cars don't have official emissions figure to get taxed on.
Great to know that i could help! Although i have to worn you that a friend of mine had his 170 tdi tuned to 257 bhp and he had a lot of problems with the exhaust gasket...It always has melted under hard acceleration. So don`t abuse on the power...
Cheers!
