Great news! Removed the DPF on leon fr
Mar 26, 2007
713
Norn Iron
Today when driving about belfast the car felt very lumpy, around 1500 - 3000 revs, very strange.. I put it down to the dpf though..
When driving home the 60 miles tomo it will hopefully tell the tale
m1_jdh
I can see some sort of silverish long thin radiator type thing but that is all...this runs flat underneath the car directly underneath the drivers side-is the DPF above this, which means it cannot be seen?
Some pics from somebody to compare would be good please...
Nov 2, 2006
1,241
Annaghmore
bebo.com
Is that not the fuel cooler under the seat, from reading i thought DPF, then cat, then pipe to rear, maybe middle box and then back box. saw a pic, it is a round ball at fromnt of exhaust.
OLDOILER
1,292
Wiltshire, UK
That is the fuel cooler!! with a long cover over it will be modifiy mine with a NACA scoop [simlar to what VW golf/passat have on the front under bib of the engine - when the weather improves
streetracer26
Good job M.Shark
I'm just about to remove PDF from my a3 2.0 170 tdi - I know that you did it , and my question is _ How your " ex seat tdi " behave , and If You had any problems in longer period after changes made _ ?
MitraShark
Newbie
Jul 6, 2006
128
Good job M.Shark
I dind`t have any problems removing the dpf and no light came on...:) The only thing that bothered me is that the ECU is programmed to make a periodic regeneration in the particle filter, although the car didn`t have it...What happens is that the sound of the exhaust becomes very loud ( like a Remus in a bad condition lol ). But you can be relaxed, because these ends in 5 minutes...
Sorry my english.
Cheers.
streetracer26
PDF - Done and dusted
Hi M.Shark
I finally removed PDF , and don't have any faults on dash :)
Big respect for You and your knowledge :) Once again well done.
My next step is to blind EGR on exhaust manifold ( already done once, but had fault every time PDF got blocked -I don't have it now, so should be ok ),and valve it self ( need to use resistors) .
With all this done I should get about 220BHP (I had 207BHP_ GIAC Remap _ ,before changes been made)
I will put my car on dyno when finished it all , and let U know
Regards
streetracer26
DPF of course
Sorry for this horible mistake :doh:
I did mean DPF ( Diesel Particle Filter )
Mar 30, 2008
621
Edinburgh
From a standard turbo, you should be able to get 240bhp. a PD170 with DPF in place can give up to 210bhp. taking off the DPF alone can yield an extra 15bhp. Another benefit of the DPF removal is that a more aggressive map can be used as you don't have to worry about clogging up the DPF. Couple the DPF delete with a non-resonated performance exhaust and you should be laughing. i'm looking to remove my DPF, but sorting the suspension and brakes before i get it done.
MitraShark
Newbie
Jul 6, 2006
128
Great to know that i could help! :) Although i have to worn you that a friend of mine had his 170 tdi tuned to 257 bhp and he had a lot of problems with the exhaust gasket...It always has melted under hard acceleration. So don`t abuse on the power...:)
Cheers!
Mar 30, 2008
621
Edinburgh
Yep, u just bolt it back on for MOT. With regards to road tax, u just pay same amount as a non modified tdi fr. Aftermarket modified cars don't have official emissions figure to get taxed on.
streetracer26
DPF Case
Cheers!
Hi Mate
You helping me more than we both could expect :)
Can U give me some more advise what to do with my engine to get it up to 250BHP on stock turbo ?
I've been thinking about injectors and fuel pump, but I'm still not sure if I can do it - any advise welcome
Any one know really good company which does good remaps for 170 2.0tdi :)
streetracer26
Don't worry to much
And I guess if you have an accident and it is noticed to be missing (long shot i know) you would be completely and utterly f****d!
Hi
I would be worry about tax or mot - If you know how to cheat ecu , then cheating mot wouldn't be a problem :)
Accidents - who is thinking about it ? Unless someone can't drive :)
Regards
