Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
Ok so its been oww... 3 months... I suppose it time for an update really! And the update is.. Its been broken for 4 months and been cleaned only a few time!
Well after i fitted my polished inlet mani i managed to break my ETG sensor.... And guess what.. there where none in the country... and i got told the beginning of Feb before i would see one.. GREAT!!
The EGT sensor monitors Exhaust gas temps and when they reach 997 (i think) then reduce the timing so your engine don't over heat.. So if its broken is performs like a donkey on ketamin!!
So.. i got a phone call from my local VAG specialist a week ago!! WOO my EGT was in.. Got it fitted happy days... Cars been ready for the stage two map since it was broken so i took a long over due trip down to AMD where they put the map on.. As well as a new MAF and Water temp sender. Then they told me its had an EGT fault. GREAT!!! It has not been fixed, so i tell them that its had a new EGT so they say it could be the wiring! GREAT!!!!!!!!!! I waited 4 months and paid £214 for something that was perfectly fine!!!!!! AAAAAAAAARRRRRRRHHHHHHHHHHHHHHHH.... *breath* well potential!!
So its going back in tomorrow to have a look at the wiring! Fingers crossed its sorted out!!
If any one want a giggle,
When AMD RR'd it when it rolled in it pulled 220 bhp (pulled 246 before it was broken) then after the stage 2 map, it managed a whopping 240!!!!!! It managed a 39 ft/lb increase as well WOOOOOOOOOOOOOOOOOOOOO yay me!!
The morel of this moan is......
EGT sensors are like girls...
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Your in safe hands with AmD they will sort it! :)
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
I know AMD are great!! But its going to Total VAG have been dealing with it. I trust Greg and im sure he will get it sorted. But im just annoyed that it might be a case of, i didnt need a new £200 sensor.. I deno.. Just want it fixed.. :(
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
Yeh, map is on and it alot quicker.. Wil just be alot lot quicker when its all finished..
Well i hope that's the case, knowing my luck it will blow up or somin. As much as i love it.. I Cant w8 to get rid of it.. I'm trying so hard to save for a house but this just EATS money!! I nee tyres as well!!
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Get the old one back on and sell the new one on.
Or see if Seat will take it back and see what sort of handling charge they want
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
Only problem is Total VAG have got my old one, not sure if they have kept it.. Worth asking i suppose. You know when you get a new thing fitted ur so excited you forget to ask for the old one back? grrrr
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
Yes very glad. Going out with Aaron tonight to have a play around with his SP3, Should get my 007p Friday, forge chucked in a free stiffer spring so i can test them both out. Ace :)
B3LSY
Hmmm so mines doing the same thing with this sensor,did you have a flat spot? vag com saying i have a EGT fault but shes still really fast pulled 271bhp/320ftlb, just after 500 miles on the engine rebuild,but the car just feels like its getting faster, hopefully when this EGT is fixed will hit 300bhp
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
Erm its hard to explain, when the EGT is broken it reduces the timeing so you dont damage the engine. But then again somtimes in some gears it pulled great.. then others its was awefull!!!
I spose i best ask really, it may save you a few bob!!
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
Ok well its still flagging up as EGT fault but my MPG are very good so im annoyed it not fixed but at least its fuling kinda right..
We put the Stage two revo up to 8-8 and seemed to run fine with only CF up to 4.8.. maybe wen then EGT is pully fixed ill try out 9-9.
Ill call total VAG tomorro but wont be able to get the car in till next week.. Laim!!!
Feb 27, 2007
1,261
Behind Wilko
LOL 9-9 sounds DANGEROUS doesnt it, but mine doesnt really pull any cf's in winter on those setting so im sure you will be fine. DO IT hehe.
