Another day just disappeared whilst working on the car. Today I redid my engine and battery cover and then polished up the inlet manifold.
Here my the balls up of an engine cover
And i know why they cracked last time... Because they did it again even before I put them back on the car... Its the shitty lacquer
Im going to have to redo them all on thus before ED38.. What a waste of time..
Ok, now on the inlet manifold, here is is after the sanding process, 80 -> 240 -> 240(wet) 400(wet) -> 1000(wet) -> 1500(wet)
After the first stage of polishing, Sissle wheel
After the second stage of polishing
And the finished result.
There is some hazing that I will have to go back to 240 to get rid off... But after the **** up with the covers and having to now buy more paint I can’t be assed to do it now!!! Ill be fitting it tomorrow, just need to pop to seat to get a gasket.
Also another f**king **** up is the bolt that holds my lower engine cover has rounded.... So i'm going to have to drill that out before i can paint it.
