removing front suspension strut?
g8rvn
154
Tamworth, Staffs
The lower seat where the shock absorber assembly has almost seized itself together.
I have taken the bolt that clamps it together completely and given it a good hammering but theres no movement at all.
Is there anything I need to do that I have missed somewhere?
tom167
bucksvag.net
Mar 27, 2006
201
Milton Keynes
I just removed the hub from the car and hit it with a hammer, i'm not convinced there's enough space to remove the strut when its all on the car....
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
There's plenty of room, just compress the springs.
beating an oil filled suspension until with a hammer - intelligent. certainly when you could just do the job with the right tools
tom167
bucksvag.net
Mar 27, 2006
201
Milton Keynes
I had no chance of getting my spring compressors in there lol.
Heaven forbid i damaged my standard shocks that i threw in the bin after fitting coilovers lol. Besides jus drives them out of the hub, not really a huge ammount of force involved jus a lot easier than fiddling around in a tight wheel arch imo
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
i just finished fitting my coilovers today :D there is plenty of room to remove the struts with the hub in place.
I used a hex bit as a hub spreader as I don't have one of the correct tools, did the job fine. Then with that in the gap I positioned a length of wood on the suspension arm and kept hitting it with a lump hammer til the hub dropped. Didn't need spring compressors til I had the strut out and had to remove the top mount. Not a particularly difficult job, just time consuming!
