Clicking / Crunching when pressing clutch
Dec 17, 2006
1,837
Bristol
Yep those retaining clips are a real pain! Oh-so-simple when you've got em figured out, but until that point.....
Didn't have any problems with the nuts at the bottom of the steering column, apart from dropping one into the rack! Took five minutes to get it out!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
those retaining clips on the pedals as well...OMG!! lol got it off eventually though and then got hit in the head by the clutch spring lol
just break em off and use a new one that's what i did
bear in mind there's a change on chassis number though
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
Just reading your thread mate and you talk about removing the shear bolts...which ones are they?
I'm just trying to remove everything else whilst waiting for someone to come round with something to get this nut off
Dec 17, 2006
1,837
Bristol
There's two of them, going up into the top of the dash, one on either side of the steering column. They're what holds the steering column up. The head is sheared off when the bolt is tight, leaving only a 'button', like in the left hand side of this picture:
They're not easy to get out, I resorted to demolishing the heads with a dremel. Then the steering column could be dropped down, exposing the thread and they could be undone.
Dec 17, 2006
1,837
Bristol
And to add to the fun, on the left one, I couldn't get the dremel in facing the normal way, so it had to put it in backwards with the disc facing me!
Enjoy :)
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Visit site
Had the same thing happed on the Cordoba, rather than spending hours removing & reffiting the pedal box I spent all of 10 minutes on iit welding the crack up in situe:)
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
That is actually a good idea.
Best idea, unfortunately i don't have to tools or the knowledge to weld
Yep I agree, that probably is the best idea. Like you though, I dont have the tools. I have the knowledge as I did it as part of my apprenticeship.
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
my made a right crack when i jumped in it today, and mates lupo did it a few weeks ago, i really really must check it this weekend.
truCido
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
does anyone know with the shear bolts if there is a washer on them?? As I've got rid of most of the bit like the pic above that alpinewhite attached, but theres a bit behind it like a big metal washer that looks like its part of it?
truCido
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
here we go! you can see the metal bit that surrounds the like button head, from the pic it looks like a washer but as I've dremelled the button bit off it seems to be part of the bolt?
