Robb1990
299
Ive tried taking the bottle out and getting rid of all the smeg attached to the sides, this worked and the bottle is now fresh, the motor is good and fresh too, but its still standing in the pipes i think, as when i squirt it, it smells bad! like sulfur and stagnant water. Briskoda say bleach, but this is going to stain my lovely paint! which i dont want. So, any idea what i can flush through it?
Cheers, rob :)
:lol: Nope. Run 2 lots of water through it today and had the motor out to try and clean it out.
proper smells like poo! :(
WIll probably do that with the front tbh, but the back will be a bitch :( Ill try some miltons sterilizing fluid for baby's see if that does anything sat in the pipes.
Anyone else find the beep for the low wash/wipe level really ****ing annoying!? the light i can put up with, but "beeeeeeeeeeeeep" *unimpressed*
Hope so! Properly stinks, have to turn off all the vents bar the one with the air freshner on then set to 'face blast mode' and put it on volume 20bazillion
You can get fragrenced windscreen washer fluid, why not try that?
Not that expensive but gives you a nice fragrence when you wash your windows!
Maybe the last owner got fed up with the beeep so they p1ssed in the bottle to shut it up :cartman:
Yes! thats what i put in, the concentrate stuff! Oh dear. :( I bet your's smells exactly the same as mine. Complaint time!
Not tried pine disinfectant.
boil a kettle stick some mr muscle in and pump on the stalk for a while for a year or so. happened to my vw pashat and worked a treat. stinks though. i know your pain
