Your Fp Green had a td06h turbine wheel hence no surge as it is sized correctly to match the comp wheel same with the red.A 20g comp wheel with a td05h turbine is a mismatch as our good friend john banks said years ago.
steve has a td06h 8cm
nope changed the hotside from 7cm to 8cm which gave me another 27bhp but i still get surge between 4700-5000rpm.yours is a td05h/20g isn't it steve? hence the surging.
on a 7cm it started spooling at 3200 and with the 8cm it spools at 3500rpm and that's with a largeport,nice intake mani and large throttlebody.that not laggy on 8cm?
killed a good 500-750rpm of spool when i ran the 8cm on the green cartridge.
all i know is that they fitted a larger 8cm hotside which i was told would make it a td06/20g.obviously not thenI'M NOT TALKING ABOUT THE EXHAUST HOUSING A/R,I'M TALKING ABOUT SIZE OF THE EXHAUST TURBINE WHEEL, IE: TD06H Turbine Wheel : Inducer Dia.: 67.3 mm Exducer
Dia.: 58.8 mm
TD05H Turbine wheel. Inducer Dia 55.9mm Exducer 49mm
Which do you have ?
that'll be where mines going wrong then.turbo not right spec for my set updifferent spec comp wheels tho. no surge ever
right ok i understand now,this would explain it maxing out at 400bhp as it's not a full td06/20g.i did wonder how mark gunns corrado was doing 460bhp when he had a td06/20g fittedi still have the td05 7cm housing so would it be best to get this fitted with the bigger turbine wheel or the 8cm one?What your saying i think is that you bought a TD05H-20G 7cm turbo then fitted a 8cm housing which would help but not alot.What you need is the TD06H turbine wheel to see the full potential of the 20g wheel.
