Cars in awesome tomorrow to check for a boost leak and a new coolant temp sensor what else would you suggest to see if they can do while its there?
ah was worth a try think dump valve aint rigth anyway as wouldent hold pressure all time on leak test.
its been pressure checked by awesome said no leak on intercooler system of tip.
stuck on it now really
Please forget logging 032. You can just look at the values for it after a long run, 032 just shows your primary and secondary fuel tweek after adjusting. These will be reset to 0 each time you clear an fault codes.
ChrsCurzon, your injector duty time looks high to me, i think, and i'm sure benny will confirm, that we see about 22ms at WOT.
SuperCupra, your maf isnt right, which is causing it to overfuel thats why your seeing -16.4 on your primary fuel tweek. Are you using a proper bosch maf?
And another thing, dont bother posting logs unless its in third or preferably 4th from low down to 6k+rpm without taking your foot off the pedal.
