Back to Square 1 no idea whats wrong
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
lol yea i know well annoying got beat by a corolla other night as just get bloody bangs and missfired when put foot down well annoyed.
Neel-Cupra
MK2 Leon Cupra 2.0T FSI
Jul 28, 2005
389
[:@] driving down a dual carriageway yesterday and the light has come back on! really getting annoyed as to what it could be, as anyone got vag-com round the west midlands area that could have a look what could be causing it?
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Had my car to a revo specialist and they've said thats its not the map thats not the problem, and they've changed my settings to HB 6 T6 and also changed my FPR from a 4 to a 3 as they said only need a 3 on stage 2 now.
They said that the problem is caused by a boost leak, which is making tha lambda sensor read incorrectly, causing it to over fuel.
Had a look for a boost leak, but can't find one, they did say it was under the battery but can't find it.
Nov 2, 2004
9,335
South Wales
wtf, stage needs a 4 bar mate.
Boost leak will cause it to run rich yes, you need to log it ideally or pressurise the system and listen for leaks.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
not according to them also rang revo and they said be okay with a 3bar to.
ill do some more logs later and see what request boost is like. did try pressure test early with a pump but was to noisey couldent hear any leaks lol. could try pumpuing with a foot pump maybe?
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
No yet doing some more logs for people to look at for me and gonna check spark plugs, got it booked into awesome for next thursday to check for a boost leak at thats what iv been told is the latest problem by a revo garage.
Put some videos in another thread to show wahts happening as got worse cant rev passed 3,500 rmp on full thorttle now.
You got yours sorted?
Neel-Cupra
Jul 28, 2005
389
No, been to midland vw today and they say theres no air leek, but theres no boost to the car, they said after doing a 115 log the requested boost is 1.2 bar and the car is running 1.5 bar! could be the remap, or 4 bar fpr .. im really sick of it now, car failed a MOT yesterday because of this problem :censored:
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
have you got a 4 bar FPR on car at the moment then?
so its over boosting then yours what you tried upto now know you had new lambda.
Neel-Cupra
Jul 28, 2005
389
tried everything, air/boost leaks, checked MAF, new front lambda sensor, could it be the NGK PFR6q plugs?? this problem only started occuring when i changed the plugs and had revo stage 2 done at the same time ..
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
have you got a 4 bar FPR on at the min though?
you could allways try some oth plugs if you think there suspect have you doen any logs to see if getting any CF's though?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Can you get any log up? My stg2 map spikes at just over 1.5bar holds for a couple of stamps then settles around 1.2bar then tails off to 1.0bar at the redline. Mine and phils are pretty much exactly the same so i assume yours would be in the same kind of range as your running HB8.
Logd would be a good start for us :)
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
yea stick some logs up super.
when i was HB9 was spiking high not sure what its doing nwo adn on HB6 and T6 :(
will do 115 118 020 002 and 114 :)
but cant rev passed 3,500 so hard to do them properly lol
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
no point in motorway in mine wont rev passed 3,500 rpm so 60 road is enough lol do 1 at a time really for best results. just dont like doing them as sounds horriable will get a proper video up to so can see and hear how bad it sounds.
Neel-Cupra
Jul 28, 2005
389
Right guys went for a spin with the MAF un-plugged and the car felt a little better :confused: but i could defo here the 007p flutter boost, has a yellow spring in it ..
