HID's - Again
GTste
168
West Midlands
fitted mine tonight. worked fine then drivers side started flickering. then realised my battery had died and then both hids wouldnt work.
so im hoping the flickering is just a result of the dead battery and not a faulty ballast.
Phil K
Here's your sign
Oct 18, 2004
548
Surrey darling...
were yours from Diane Shop? If so, how long ago did you order them?
I'd have thought, knowing how HID lamps work it is more than likely it was your battery that caused them to flicker and then fail - you'll find out for sure as soon as you're fully charged/running again!
Did you run into any issues with the fitting or was it as easy and straight forward as it sounds?
GTste
168
West Midlands
yes they were, they came last week and got round to fitting them today.
fitting was fairly straight forward, managed to support the ballasts with a bolt in each one along with a strong cable tie for extra support.
just a bit fiddly in places but its all mainly plug and play. only problem i had was that the 2 wires that go into the standard bulb were both black instead of red and brown, so just went by the other side for comparison.
going to get it jump started when it stops raining then take it for a quick drive to get some charge back into the battery, hopefully no more flickering!
Dec 31, 2007
1,479
Reading
I installed mine today, I thought it was going to be lot harder than it was. The worst bit was deciding where to put the ballasts, I need to look back through this and see where other people have tried!
GTste
168
West Midlands
has anyone uprated there full beam bulbs?
i know people say you dont need them with HIDs but its just nice to have matching bulbs.
DodgyDave
121
Glasgow, Scotland
Not any point... HIDs take afew seconds to get to full brightnes, so unless you drive with 'em on all the time they are not that great.
Also HIDs dont like being turned on/off due to the way they start (very high voltage/current spikes) so they would not last that long :think:
Dave
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
Dave
I've had HIDs in my High beam since about Feb last year.
I admit they do take a little time to get warmed up, but OMG once they're up to temp they're fantastic, I doubt I'd go back to be perfectly honest.
As for longevity, I've not had to replace a bulb as yet...(touches wood)
It really depends on the kind of driving you do. If you spend most of your time on middle of no where roads with trees over-hanging then I can only recommend High beam HID's. If you don't then it's probably not really worth the money.
Oh an one last thing, you have to make an ad-hoc bit of wiring to fit H1 HID's (for the High beam).
PaulLC
85
Tyne & Wear
Why would you want to .....
Standard 50w @ 12v = 4.2amps each (so 10amps for both)
HID 35w @ 12v = 2.92amps each (so 5.84 for the pair)
HID's use less power for the same light output ;)
Dave
Because in the HID instructions i got it recomends you change them to 20 amp (standard thats in my LC = 7.5amp)
DodgyDave
121
Glasgow, Scotland
Been running the same set for 2 1/2 years, perhaps more now ... not changed the fuses :)
But remember that a fuse is a safety device, designed to stop fires ... if the cable is only rated at 10A and you stick a 20A fuse on it ..... what will happen if there is a fault ????
Dave
Phil K
Here's your sign
Oct 18, 2004
548
Surrey darling...
Fitted mine this afternoon and all I can say is WOW! Night and day difference... I can not get over how much better HID's really are and only wish I'd done this sooner!
I'm currently leaving for work and coming back home in the dark so this is going to be the best sub £50 mod I've ever done - totaly chuffed :D
Fitting took no more than 35mins too and having read the guide previously it was very straight forward...
Can't beleive how yellow other cars lights look in comparison now :lol:
Deleted member 7729
I'm waiting to complete my house purchase before looking a these again. Just a shame the car has 74k :(
Empi5
Your scaring me.......
Feb 24, 2005
2,807
Staffordshire
Well my replacement bulbs have arrived. Diane Shop did say to return the blown bulb, but its probably more hassle than its worth.
