But if you mould it on top of the old covers.. the covers fit flush with the plastic frame, now with a couple layers of CF, wont this be "not" flush and have a ridge along the mirror casing? And also if the CF is folded around the edge of the cover to make a neat edge, this will pull the cover away from the flush edge and thus, not allowing the plastic clips on the inside to come into full contact with the holds, and thus back to the start of a cover that doesnt clip on..?
If you look closely at the covers, there is an ever so slight difference in height between the outer and inner casing, admitadely not enough to not have some form of difference in height. HOWEVER, the idea would be to blend to the edge therefore minimizing the step.
You would not fold the carbon round the edge of the mirror, it is very very dificult to fold carbon at 90 degress and get it to stay in place whilst it sets - you also runt he risk of air pockets, bubbles etc ect, it also can distort weave etc, so you would finish it flush with the edge of the part.
I've had a look at the covers listed earlier in the posting form vw4sport, and believe that with these they are actually the original covers covered in carbon - if you read the notes on the part it says there is a $40 surcharge untill you return your original core, I assume therefore that the core is the original casing, and hence why they fit using OE fixing method. Look at the other carbon parts they do and they ask for you part first before they can make, again this hints at being wrapped or covered parts.
Anyways, so what I have done is as follows:
I have ordered a set of the std teardrop covers from our local TPS branch - they are cheap enough so no worries with doing this and they woudl fit my car anyway so wont break the bank
. This way I can look at them and see how the fix on etc with a view to see how difficult it is to reproduce the fixing system. I'm a noisey bugger so want to see this without the hasle of dismantling my own car.
I then have a few options as below:
Wrap the casing as it is. This is ok if there are not many to do as wrapping / covering can be time consuming to do; if there are more to do then a mold woudl be a better option. this would then mean the best method woudl be a two part mold, one for the outside and one for the internal finish of the carbon cover. This way it means you can get the Carbon as thin as possible and use the mold to radius of you like the finishing edge or blend it slightly int he mold. this would then allow the cover to be bonded to the original casing thus retaining the OE clip system (this is after all what vw4sport appear to be doing ?). I have other work on as well on VW stuff at the mo' so wil ltry and look at this in between jobs when it can.
If things dont come thru for MDS then we have an option this end to look into it further (and at the end of the day if I wrap a set anyway, i could put them on my own car
). This would then allow peeps to see wha they look like fitted etc
