So does it go above 60mm down to 60mm then up again?
Or under 60mm up to 60mm, back down to under 60mm?
Just wondering, if pressure might come into the equation? Sucking a hell of a lot of air in...
Dunno, just a thought?
I think a fat pipe straight onto compressor inlet would help, means the flow of air stays constant...
Mike
Intake might help with the spool, but the high end duty cycle makes it look like it'll do more - as long as you're comfortable with that - 1.4 bar at 6,500 is stonking.
Have you had a chat with Kev about it? Would be interesting to what they think of the logs/map.
)Any updates?
) Because of the lack of room, all three components will have to go down together and then be jiggled in relation to each other so that the bracket can bolt in.i was thinkin about the gt28rs on my ibiza was just wounderin how it was to install
How's your TIP Dave, have you fabricated a solution to the gear linkage obstructions !
Here are some logs from my LCR on standard APR stage two settings showing temps at both the DP and CAT to enable you to guestimate DP temps. I was surprised how quicky the temps dropped over such a short distance.
43 ------------------------------------------------112
208.35 2680 485 0.875 B1-S2 OK 207.75 725
209.26 2800 490 0.845 B1-S2 OK 208.66 715
210.27 2600 495 0.9 B1-S2 OK 209.65 700
211.17 3600 500 0.88 B1-S2 OK 210.57 695
212.08 4000 515 0.865 B1-S2 OK 211.47 690
212.98 4440 530 0.875 B1-S2 OK 212.38 700
213.89 4840 540 0.875 B1-S2 OK 213.28 740
214.79 5160 560 0.88 B1-S2 OK 214.19 780
215.7 5480 575 0.88 B1-S2 OK 215.09 805
216.7 5760 595 0.875 B1-S2 OK 216.01 830
217.61 6000 610 0.88 B1-S2 OK 217 855
218.52 6200 625 0.875 B1-S2 OK 217.91 870
219.53 6440 640 0.87 B1-S2 OK 218.82 880
Dave - what are you going to do when you actually finish it ..... you're going to be lost!
There's a large, broken down farmhouse within 20 km of Avignon in France waiting for full (self-build) renovation. Only problem is, I need to sell this house first in order to buy it. If things had gone to plan, the car would have been sold with only the Fabia rear wiper done.
Does anyone think the RamAir might be restrictive?
I guess you'll be driving frances fastest LC then whilst rebuilding your new house![]()
bigger large cone and some heatshield/ducting next step... like badgermobile Dave
RamAir is too small for your setup now
yea.. on holiday officially.. leave country tomorrow..
trying to unwind.. (failing miserably mind you reflecting on cars breakages yesterday, thumping headache.. - will put laptop down and forget cars. F1's about to start race now tho)
Stressed.. hopefully not so after a couple of weeks of nothing but snorkling in warm indian ocean
I've just come back from four days away- not enough.
