Yeah thats what i was on about, get it up and away from everything.
I'd buy a high flow mani anyway if i got an eliminator.
Heres a question tho, if you could get a k04 downpipe would it be easier and get more power if you went for a GTRS k04 eliminator version.
I know you'd stil have to fab a downpipe but fitment issues of the inlet and whole normal fitment issues of a proper GT28RS wouldnt be there.
I'm just thinking that Hooch had a k04 fitted to his Ibiza with no fitment/room issues.
Friday 5 October 2007 19:47:57
06A 906 032 HN 1.8L R4/5VT 0002
Group A: '003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
/min g/s % °BTDC CF CF CF CF
3160 66 100 15 0 3 3 3
3320 76.69 100 23.3 3 6 3 3
3520 87.08 100 22.5 3 6 6 3
3680 98.83 100 13.5 3 6 6 2.3
3920 119.47 100 12.8 2.3 6 6 2.3
4200 139.33 100 9.8 2.3 6 6 2.3
4440 155.81 100 7.5 2.3 5.3 6 2.3
4680 176.69 100 5.3 2.3 5.3 5.3 2.3
4960 183.5 100 6 2.3 5.3 5.3 2.3
5200 182.14 100 7.5 2.3 5.3 5.3 2.3
5440 189.53 100 12.8 2.3 4.5 5.3 1.5
5680 195.08 100 11.3 1.5 4.5 4.5 1.5
5880 204.44 100 12 1.5 4.5 4.5 1.5
6080 205.36 100 16.5 1.5 4.5 4.5 1.5
6240 209.75 100 15 1.5 3.8 3.8 1.5
6440 211.08 100 15.8 1.5 3 2.3 1.5
6600 209.75 100 16.5 0.8 2.3 1.5 0.8
6760 215.78 100 18 0 0 0 0
Friday 5 October 2007 19:51:12
Group A: '115 Group B:
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor Lambda Factor
/min % mbar mbar
2600 94.7 1410 1300 0.969 0.953
2760 100.8 1460 1370 0.93 0.938
2880 106.8 1930 1430 0.914 0.922
3080 112.8 2030 1520 0.875 0.875
3280 120.3 2090 1630 0.836 0.844
3440 130.1 2160 1740 0.805 0.828
3640 141.4 2280 1890 0.789 0.813
3880 159.4 2400 2080 0.789 0.805
4120 172.9 2470 2350 0.789 0.805
4360 189.5 2470 2530 0.797 0.805
4680 191.7 2450 2540 0.789 0.805
4920 191.7 2410 2540 0.805 0.805
5160 185.7 2400 2460 0.789 0.805
5360 182 2410 2400 0.789 0.805
5600 182 2400 2350 0.789 0.805
5800 180.5 2410 2390 0.797 0.805
5960 178.9 2410 2410 0.805 0.805
6160 175.9 2410 2380 0.805 0.805
6320 171.4 2420 2360 0.789 0.805
6480 171.4 2410 2370 0.797 0.805
6600 166.2 2390 2450 0.789 0.805
6720 163.9 2380 2420 0.797 0.805
6840 160.9 2370 2440 0.797 0.805
6840 115 1010 2310 0.75 1
Friday 5 October 2007 19:52:52
Group A: '118 Group B: '032
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Idle O2 Adapt Run O2 Adapt
700-6800 RPM <=110 C 0-100% <=1800 mbar -10.1 -10.1
/min °C % mbar % %
3120 21 0 1260 0.6 0.8
3200 21 100 1300 0.6 0.8
3320 21 100 1520 0.6 0.8
3480 21 100 1700 0.6 0.8
3720 18 100 1910 0.6 0.8
3920 15 100 2120 0.6 0.8
4120 15 88.2 2310 0.6 0.8
4360 15 76.9 2440 0.6 0.8
4680 17 65.1 2530 0.6 0.8
4880 18 58.8 2540 0.6 0.8
5120 18 49 2480 0.6 0.8
5360 18 47.5 2360 0.6 0.8
5560 19 49.4 2380 0.6 0.8
5760 20 49.8 2410 0.6 0.8
6000 21 50.2 2430 0.6 0.8
6160 21 53.3 2400 0.6 0.8
6360 21 54.1 2420 0.6 0.8
6520 21 53.3 2390 0.6 0.8
6680 22 47.5 2390 0.6 0.8
6840 22 45.1 2330 0.6 0.8
6720 18 0 1420 0.6 0.8
I thought it might help with the timing more than that? Where's the nozzle?
I mean, if you can run it on HB11 and T11 (Spinal Tap reference) and still get accepatble timing pull, it's doing a good job.
Or is that not what you meant?
I hadn't really looked at it that way. Thank you, Phil. Friday 5 October 2007 19:39:42
3000 61.69 100 27.8 0 0 0 5.3
3120 68.33 100 23.3 0 0 0 5.3
3320 79.08 100 21 0 6 3 5.3
3560 91.89 100 23.3 3 6 6 4.5
3760 109.58 100 13.5 3 6 6 4.5
4040 130.97 100 15.8 3 6 6 3.8
4320 152.11 100 9.8 2.3 6 6 3.8
4560 168.56 100 6.8 2.3 6 6 3.8
4840 183.22 100 6.8 2.3 5.3 6 3.8
5080 182.17 99.6 8.3 2.3 5.3 5.3 3.8
5320 187.58 100 12.8 2.3 5.3 5.3 3.8
5520 196.03 100 14.3 2.3 5.3 5.3 3.8
5760 199.22 100 11.3 2.3 5.3 5.3 3
5920 205.39 100 15 2.3 4.5 4.5 3
6080 200.5 100 15 1.5 4.5 4.5 3
6200 205.61 100 17.3 1.5 4.5 4.5 3
6400 205.61 100 15 1.5 4.5 4.5 2.3
6520 210.08 100 17.3 1.5 3.8 3.8 2.3
6680 209.83 100 16.5 1.5 3.8 3.8 2.3
6800 207.72 100 19.5 0.8 3.8 3.8 2.3
6960 206.06 100 21.8 0.8 3.8 3.8 2.3
7040 203.42 100 18.8 0.8 3 3 1.5
Timing pulls still look a little high tho dave.
What plugs and gap are you running? You might need to regap your plugs smaller.
Looking good tho.![]()
I think 50 / 50 is a little strong mate.
Mine was running 20% and that was richening it up too much when it was on dyno and actually caused a slight power loss, But if it is mapped with methanol ON then all will be sweet, just dont run out.
PS: i have about 4.5 Gallons of methanol sitting at work, i shal bring it to JBS for you mate, its no good to me anymore.
Dont want anything for it mate.
are you running wide band lambda gauge? this would be useful for monitoring what effect the methanol has on the A/F ratio.
Iam also running IK22 on standard gap, this should be fine for yours i think.
/min % mbar mbar
Excellent results there Dave.
How painful was the install and what does the Butt Dyno say.
Big ass Tip still needed to spool that turbo a bit sooner though.![]()
