Sorry to bother you boys but im abit stuck on this one, Dont really know what to do for the best.
I had a set of HIDs delivered today and when to fit them. I have got to options according to the instructions. Just switch th bulbs over, install the ballests and plug together. Plugging the two ballests into the original plugs for the old bulbs.
The other is to use the relay cable they gave me and do the same as above but use the power direct from the battery instead of the original plugs for the old bulbs.
The only advantage to this i can think of is that you will be using a separate relay and fuse instead of the one from in the car originally.
What have you boys done
Ive got them hooked up using the first method at the minute and i will say, anyone that is thinking of buying these. DO IT NOW!!!!!
