Sorry guys, just wanted too make sure everything was ok before saying its running.
But i have done 110 miles so far and all is very very well.
I had a very minor leak from oil cooler union which is sorted.
Car is very very quiet, its a bit strange really, but turbo's act as a silencer, even though it only has a rear silencer.
I have started pushing it a little while monitoring air/fuel which seems to be sitting low 12's when under boost, but i have yet to see what the timing is doing.
I accidently hit 1.9 BAR last night and got some 5th gear wheel spin, but it was a bit wet.
The rear section of the exhaust needs to be adjusted a little as iam get a rattle every so often over large bumps.
The turbo is producing 1 Bar boost at 3000 - 3200 rpm which i was very suprised about, and i dont get the typical woosh noise from the DV, but a nice WRC chatter.
I will get some pics up soon although there aren't many from the rebuild as i just got my head down to get it done.
When the engine is cold iam getting a slight top end rattle which i think is piston slap, due to the fancy bits inside, but soon goes as soon as the engine has some temperature.
So far iam a very happy man. Iam planning on doing the gearbox weekend after next then off for some CC 3.
