Project Cordy - My old 16v reborn
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Visit site
nah, they come off easy :D i had no bother once I'd skinned my knuckles
mission yes, but not beyond your abilities I'm sure - just be methodical
while the engine was out the car.......[B)]
I'd be inclined to drop it off at the down pipe for some reason, not that you can get the down pipe in and out without swearing in situe.
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
id do it now pete and get the head reskimmed as its probably out by now
saves your block then :)
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
thinking on though, its probably going to cost you about £300 to do that, and a 'new' abf is only £500 (breakers)
Icecavern
6,214
Berkshire, UK
www.icecavern.com
Thing is the engine has only done 55k and runs sweet as anything. But I have an oil leak I want to fix. I need to clean the back of the engine and check it's definately coming from the head gasket first.
I was hoping this oil leak would be an easy job :(
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
if the engines been sat for a while, the gasket may well have perished and be giving up as its being reheated
Icecavern
6,214
Berkshire, UK
www.icecavern.com
Well it's been sat for about 8 months without much use, and without being driven. But as I said it had an oil leak when I had the car years ago. I'm guessing it's the same problem now and it was never fixed. It doesn't loose any oil if left ticking over, only when it's driven and under load.
Tom B
4,710
16
Northampton
I found that if you remove the front arch liners, the sides of the bumpers are prone to come loose.
If you do remove them, you'll have to find a way of securing the sides to the wheel arch end of the wing.
Icecavern
6,214
Berkshire, UK
www.icecavern.com
I've taken them out for a trial but the intention is to modify the liners and put them back in eventually. I'll probably try taking a heat gun to them to flatten out the bump in the front of them, the main thing is working out how to keep the clearance on the outside too as the tyres look to be just catching the bolt heads on the outside arch. Rolling the arches will sort that, but then the liners wont have anything to hold them in place, so working on that one ;)
Icecavern
6,214
Berkshire, UK
www.icecavern.com
Its not going to be your daily drive though is it??
Ditch the aircon and open the windows ;)
No it's not, but it is going to be used as a sound quality competition car... It's customary on a hot day to run the car for 10-20 mins with aircon on full blast prior to judging so that the judges have at least some time sat in the car before it turns back into an oven. Hence wanting to keep aircon.
