Cheers Steve.Well I've just been away for a week so just catching up on reading last weekend onwards, have to say your doing a great job.....keep going.......
Too easy to stick an elbow on the outlet a la TIP, Phil. A nice fatAhhhh, now I see what your problem was.
Forge reducer has plenty of length (fnarr-fnarr).
I was going to say that if it doesn't work permanently and if your tame welder can do ally, you could hack the inlet adaptor and point if to the right angle.
But from what you said before, if this doesn't work you'll be designing your own inlet...
So this is the only thing stopping the car being started now dave?
When you get chance any chance you could take a few pics for me of the inlet bolted to the turbo and the room between that and the shifter cables. I wanna make make my mind up whether its worth goin DIY on the inlet or buying it.
I'm sure you've done your best (better than all the rest), but that made me cringe a leeeetle bit.
Especially considering the ovalness of the ATP Casting.
Is the casting good quality - do you think it's weldable?
Yeah i read that any degree bends cuts airflow by a certain percentage. But whatever way you look at it your going to have some serious bends just because of the low down position of the inlet on the turbo. I might have drawn it a little acute but you might be able to get away with a large degree bend off the turbo, to get up and over the shifter bracket.
Personally i cant see it bein too bad as IHI uses a standard TIP design to get up to the MAF and the ATP inlet kit goes through a 90 degree bend. And doesnt Robdon use a cobra head 90 on his GT2X?
Food for thought anyway.
DPJ's GT28RS Eliminator Install - Page 7 - SEAT Cupra.netWith the ATP big bore inlet and brackets out, I took time to weight the thing up. Long term, the big bore has got to go. I was about to set to with a ...
www.seatcupra.net/forums/showthread.php?p=1451564 - 139k -
Dave, you are now offically the world expert on the installation of the eliminator turbo and large bore inlet.Any idea what bore ATP's inlet kit is near the compressor inlet?
By the time mine turns 90 degrees, it's over 80mm dia.
I googled ATP big inlet and the third item down says
Standard bore on the turbo inlet on the GT28RS? I thought you knew that dave as you had it sleeved to take it to 3"
I'm sure people have used this in a similar way i was talking about...
http://www.atpturbo.com/Merchant2/m...oduct_Code=ATP-SIL-251&Category_Code=SIL-90EL
Forge do a 76mm to 63 reducing elbow, which if the stock inlet diameter is 63mm it would be perfect to get up and out of the inlet and into a 3" pipe.
